Question about Keurig Elite B40 Coffee Maker
Alll of a sudden it will only brew a half a cup when we press the button for the large cup.
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 22, 2011
I keep getting small cups of coffee.
I have one of these coffee makers also and having the same issue. The machine is getting limed up. Run some vinegar through it. What I found also a little trick is to turn the machine on, place a cup underneath like you were brewing a cup and press the brew button. Let the remaining water come through and the next time you will get a full cup. But this does not solve the issue. Liming seems to be the issue with these makers.
May 14, 2016 | Keurig Coffee Makers & Espresso Machines
My Keurig B40 has three different size cup sizes available, but it dispenses the same amount of water for the medium size cup and the large cup of coffee. It's barely been used so It doesn&am
I realize you think it does not need descaling to to it 'not being used much.'
However you may have hard water and I would think descaling is definitely worth a try. There might be scale built up on the water level probes in you machine.
Descaling Details are listed below:
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
(DO NOT USE A K-CUP)
Just press the BREW Button. Pour the contents of the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until "ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink.
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew cycles if you notice any residual taste.
Nov 20, 2014 | Keurig B40 Coffee Maker
Why is my Kuerig B60 coffee maker not filling the correct amount of water. ie. a cup instead of a mug or 2 instead of 3rd level?
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Apr 14, 2013 | Coffee Makers & Espresso Machines
How to reset keurig b40
1. There is some confusion over models. I've seen "B40" models and instructions with only one size cup button, both labeled B40. I own one stamped "B40" on the bottom, and it has two buttons -- small and large. FWIW, small = 8 oz, large = 10 oz.
2. These reset instructions from another site seemed to do something
What to Do If Your Keurig Won Brew Cup Barista
So.. this is what I did that worked for mine: 1) Hold down Auto-Off and LARGE cup at same time. (all lights should hold steady ON) 2) press SMALL cup while still holding Auto-Off and LARGE cup 3) Release all three, press LARGE cup again.. all lights should go off. 4) Unplug for about 5 - 10 second, plug back in. SHOULD WORK!
3. On *_my_* B40, remove the K-cup, close the door, fill the reservoir. Unplug and replug the B40. All lights should be off.
Pressing "Auto Off" and "Large Cup" together will turn on 3 lights (Heating, Add Water, Power) for about 3 seconds. Doesn't matter how long the buttons are pressed or what order they are released.
I tried lots of add-on combinations: e.g. press button x, press x multiple times, press x while lights are still on, press x after lights are off, press buttons x and y together, press x then y, press x and/or y while still holding Auto and Large, release Auto but not Large and press x, etc.
Nothing gave any confirmation that a reset was accepted. All lights always turned off after 3 seconds. Maybe Reset is only 1 step, i.e. Auto+Large together?
Jan 04, 2013 | Keurig Elite B40 Coffee Maker
Keurig b60 won't dispense water
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
Step 3:
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
Dec 14, 2012 | Keurig B60 Coffee Maker
I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
Mar 17, 2011 | Keurig Special Edition B60 Coffee Maker
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
I press the large cup but it brews a small cup. What should I do to fix this?
I have have the same problem first thing in the morning. My first cup, I press large but with no K-cup; it comes out small or medium. I put the water aside (pour it back into the reservoir after it cools.) Then I brew a large cup using a K-cup, and it comes out the right size. I still want to know how to fix the problem, but at least this works for now.
Aug 11, 2010 | Keurig B60 Coffee Maker
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Keurig Elite B40 Coffee Maker Logo
260 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
