Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Whirlpool LT5000XSN1 - Stackable Thin Twin, Washing machine fills with water but the agitator cycle never ends... so, I have to turn it off and drain the water with wet/dry vac... basically, it will not go into spin cycle or drain... can you help?
  • cpainter77 Mar 22, 2011
    I appreciate the guidance, can the switch be bypassed to test this recommendation... perhaps disconnecting it would allow me to facilitate this action? If disconnected, would it cure this problem and confirm your recommendation? If the switch is replaced to no avail... what would be the next time step to resolve this issue???
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
The lid switch is likely bad. It should click when lid is opened and closed.
Kelly
Posted on Mar 22, 2011
  • Smitty Mar 22, 2011
    Yes, if you bypass it you should be able to verify the diagnosis. The switch wires must be connected together before the washer will work. It is designed as a safety to prevent injury if you were to put your hand in while the machine is running. If you do not hear a click, the switch is bad.
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
My thin twin wont drain. Checked drain pump and it was clear. When i got all the water out it would spin. It will fill, agitate and spin(as long as there is no water)
The basket drive and or clutch need replacing, as long as their isn't the added weight of the water it spins yet add 250 pounds of water weight its slipping
Aug 03, 2011 | Whirlpool LTE6234D Top Load Stacked...
Hi, I own a Whirlpool Thin Twin Model# LT5000XSN1. I bought it used from a CRAPPY dealer (worst mistake EVER), since day one, we have had an issue with the spin cycle. The cycle will agitate then when the...
This sounds like a classic clogged empty pump issue. The empty cycle is timed and then it steps on to the spin cycle. The machine won't spin if there is still water in the bottom of the drum. When you reset it to a spin cycle again, you are making it run through the empty cycle again, finally getting rid of the water that the clogged filter could not evacuate on the first attempt.
You need to clean the empty pump filter. Now... Where is the filter???? Hmmmm... not sure. It MAY be behind a little panel in the front of the machine near the bottom. I can't find a picture of the machine on the net so I'm not sure.
Clean the filter, I'll bet your problem goes away. You have to wonder why the idiot who sold the machine to you hasn't suggested this!
Jun 21, 2011 | Washing Machines
My whirlpool thin twin wont agitate on any cycle or spin
broken motor coupling....if you need help replacing..im onthejob
Jan 03, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    My washer does not work
    Sounds like you may have a lid switch problem. Without a model number, I really can give you a part number (Kenmore Stacks are made by two companies, Frigidaire and Whirlpool) or a way to get to it. It is right under the lid. Check the top and be sure that the plunger that goes into the hole isnt broke or missing. If you need further help, send me the model number (will start with 417 if its a Frigidaire or 110 if its a Whirlpool) and will try to get you a little more information. The job on either unit isnt that hard, and parts are pretty inexpensive. Let me know. Jim
    Dec 13, 2007 | Kenmore 98702 Stacked Washer/Dryer
    Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
    832 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
