Question about GPS
I press the power button for ten seconds, it starts to come on then it shuts down.
    Genius:
  • 1,098 Answers
Hi there.
Two reasons could cause this. One is corrupted firmware or you need to replace the battery inside it.
Reset the device to solved the issue of the corrupted firmware. Locate the reset hole, there should be one, it is a tiny hole than only a pin can fit.
If the battery can not be removed, check the fuse in the power cord and in the vehicle, replaced them if blown.
Hope this helps.
Posted on Mar 22, 2011
Leapfrog ipad ultra black screen white dot
During a normal shut down, the screen image on a LeapPad will reduce to a white dot, which will disappear in five to ten seconds.
In rare circumstances, the white dot will not disappear and the LeapPad will not fully power down. If the LeapPad does not complete the shutdown process and the white dot remains on the screen for more than ten seconds, complete the shut down by pressing and holding the power button on the LeapPad for ten seconds. This will fully power the LeapPad down, and it will start up normally next time you power it on. For more information contact essay writing service reviews
Essaypaperreviews com Best Writing Services Reviews online
Dec 27, 2013 | LeapFrog Toys
V3-531 reboot without disk
You don't need disks to reboot. Just click "Turn off computer" under the start menu, and then click "Reboot". If that doesn't work, hold down the power button. After ten seconds or so, your computer will shut off, and you can restart it again simply by pressing the power button again.
Jan 31, 2013 | Computers & Internet
Hp slimline s 3000 wont start green light for ps goes off when start button pushed
You seem to have eliminated the PSU as a cause of the problem.
It might be that there is short circuit somewhere in your case, possibly one between the m/b and the case. This could cause your PSU to shut down (if it has s/c protection). Holding the power button for more than a few seconds would cause a power down (mine is power on when the button is pressed, but pressing again/continuing to press for 5s causes power down: to power down, the power button must be pressed for the 5s - to prevent accidentally pressing the power button from switching your machine off by touching the power button).
If this is the cause, probably the only way to solve it is to remove the m/b from the case and clean out the case and the m/b, the latter with canned air perhaps. (you should inspect the surface of the m/b for objects which might be causing such a s/c, but most likely any object has become lodged behind the m/b. Some computers allow removal of both side panels) Be careful during re-assembly because some m/b-cases require (either insulating or conducting) spacers/stand-offs between the m/b and mounting points in the case.
Of course, there may be another cause...
13.April.2014
Jul 08, 2012 | HP Pavilion Slimline S3123W Desktop PC -...
Cannon MX340 printer - error code 6500
If the printer is not working properly or to clear memory try this:
1. On the operator panel, press and hold the ON/OFF button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the ON/OFF button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Or Try This:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
1. With the printer powered on, press and hold down the Stop/Reset button then press the ON/OFF button.
2. Once the printer is powered off, hold down Stop/Reset and then press ON/OFF.
Or Try This:
Reseat the printhead (printhead may also need replacing)
Aug 13, 2011 | Office Equipment & Supplies
Shut down in sleepmode by mistake, how to awaken?
Press enter twice or press power button to awake.
Thanks,
satheesh
Jan 20, 2011 | Computers & Internet
How do i get e machines out of safe mode so i can reboot the computer?
If you are in safe mode, you should be able to shut down or restart the computer the same way you would in standard mode. Click the start button and select shut down or restart, and let it boot up normally. If you do not have the start button, you can try holding down control-alt-delete and selecting shut down from the menu. If all else fails you can hold down the power button on the computer for about ten seconds and the computer should power off, then you can turn it back on.
Jul 21, 2010 | E-Machines eMachines Desktop PC
Startup switch on PB G4 17 not getting apple sound, takes numerous times to boot up. Using Tiger OS, upgraded to latest. Works fine, otherwise.
If a Mac is shut down while the volume is set to zero, the standard Apple startup chime will not sound, so it is impossible to say whether or not this symptom indicates a problem.
For a startup issue such as this, I would recommend zapping the PRAM and resetting Open Firmware.
To zap the PRAM, start with a powered-down machine, press the power button, then immediately hold down the four keys: command, option, P, R. After ten seconds or so, you should hear the optical drive reset, and then the startup chime (because the volume is reset to full by this procedure). Ten more seconds, another reset, another chime. After the second time you hear the chime, release the keys.
Shut the machine down again (if it doesn't start up successfully, hold the power button until the power goes off). Press the power button, then immediately hold down the four keys command, option, O, F. You will see some tech-speak on the screen, then it will wait for input. Enter the following three lines, pressing the "return" key at the end of each:
reset-nvram set-defaults reset-all
After the last line, your Mac will reboot itself. It should now boot much more reliably. If it doesn't, chances increase that you have a hardware problem. You may want to run the Apple Hardware Test from the DVDs that came with the PowerBook to check your memory and logic board. Failing this, you are in for a trip to the shop.
Oct 05, 2009 | Apple PowerBook G4 Mac Notebook
Phone doesn't power on
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Aug 12, 2009 | Apple iPhone Smartphone
Pumps for a few seconds then stops & pumps again for another few seconds & so on
The toilet will flush normally and shut down. Then imediately after it has shut down, as it should, it will start up again and keep going through the flush cycle until I unplug the power going to the pump. After about ten minutes, I can plug it back in and it then will not start up again until I press the flush button.
Jul 01, 2009 | Saniflo Sanibest macerator with multiple...
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
GPS Logo
23 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
