Question about JVC AV-36D502 36" TV
JVC AV-36D502 belonging to my 99 year-old father somehow got set to close captions (i managed delete the closed captions) and SAP. i cannot get the SAP setting changed to STEREO. using the menu i can get STEREO highlighted, but the TV is still in SAP mode. i don't understand exactly how things are selected in the menu--the manual says toggle up and toggle sideways, but says nothing about how to lock in changes. best i can do is make changes and quit the menu, but the SAP selection is unchanged after i have done that. thanks. keith
5 Suggested Answers
SOURCE: Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Posted on Mar 22, 2008
  • 106 Answers
SOURCE: How to remove closed caption from JVC TV without original remote
Try to get a univarsal remote a desent one at 15$ at walmart then try to use menu to, or unplug for 15 min then plug back in these should work.
Posted on Mar 19, 2009
  • 541 Answers
SOURCE: I have a JCC AV-32D305 television. I use Direct TV
Unfortunately JVC had closed caption buttons on the remote and that is the only way to change the CC settings. Go to www.remotes.com and check to see if they have a remote for your set. Thanks
Posted on Nov 02, 2009
Testimonial: "Accurate in his comments! Also provided website to procure needed remote."
SD Tech
  • 14553 Answers
SOURCE: JVC model AV-32750..... The close caption
just look in the section for closed captions----the box is the "text" feature and just needs to be turned off; if you did it without a remote it can be undone the same way.
SD TECH
Posted on May 13, 2011
How to turn off CC to get rid of that black box
Here's the link to the manual. CC instructions are on page 22.
http://books.jvc.com/Download/77833385/LCT0604-001B-A.pdf
Closed Caption
Use this function to display the Closed Captioning
text onscreen (when included in a bro a d c a s t ) .
P ress the ME N U b u t t o n
To CLOSED CAPTION
To operate
To select Caption, Text, or Off.
To CAPTION or TEXT
To select a caption or text channel
To FINISH
To save setting and exit
Dec 31, 2012 | JVC AV-20120 TV
JVC model AV-32750..... The close caption feature is toggled on and a large black square is blocking picture. I have no remote to enter the menu settings so using buttons on bottom front. I am unable to...
SD TECH
May 13, 2011 | JVC AV-32750 32" TV
I have a JCC AV-32D305 television. I use Direct TV and the TV remote has disappeared. And since the closed captioning is on, I get the "box" in the middle of the screen and it cannot be turned off with...
Nov 01, 2009 | JVC AV-32D305 32" TV
Jvc 48in projection tv
Somehow you have turned on closed captioning in TEXT mode. Navigate the setup menus to find the closed captioning options and turn it off.
That should resolve the problem.
Dan
Mar 20, 2009 | JVC AV-48WP30 48" Rear Projection...
how can i get rid of the closed caption on my magnavox tv without the original remote
Mar 19, 2009 | JVC C-20810 TV
Turning on closed captioning
Some older telivisions don't have the option hoever caption with always be under the menu. Or if your playing a DVd then under the language set up.
Feb 12, 2009 | JVC AV-20220 TV
JVC AV 3151s
I know this is a pretty old post, but maybe you'll see this. Here is a link to the manual on JVC's site:
http://resources.jvc.com/Resources/00/00/99/LCT0305-001B-A.pdf
Jul 27, 2008 | JVC AV-20220 TV
JVC AV-32050
Probably the text box for closed captioning. Turn off the closed captioning and see if it goes away. If not, then, try setting everything back to the factory presets. Your manual will tell you how.
Jul 17, 2008 | JVC AV-20220 TV
Apr 10, 2007 | JVC AV-32F704 32" TV
JVC AV-27D500 27" TV
The closed caption or PIP functions in mostly all sets are only acessable trhough the menu.. You need the original remote to do this. If you dont have one go to http://www.remotes.com or call 1-800-remotes for inexpensive exact replacement remote controls. If you do have the original remote and can acesess the menu but the features are not there then theres a problem with the sets built in firmware and the only way to fix this would be to replace the sets microprocessor IC. Good Luck
May 21, 2006 | JVC AV-27D500 27" TV
JVC AV-36D502 36" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
