Question about Homedics Automatic Arm Blood Pressure Monitor ()
Lately when trying to get blood pressure "EE"
    Brigadier General:
  • 4,736 Answers
The EE symbol can mean one of three things: Excessive low blood pressure, improperly placed cuff or movement of the arm during the measurement.
Hope this helps solve the problem. If it continues, contact HoMedics Customer Service @ 800-466-3342
Posted on Mar 22, 2011
What does ee mean on the omron blood pressure monitor/HEM-731C?
is it a 780 or a 731? found manual for 780; http://omronhealthcare.com/wp-content/uploads/hem-780-instruction-manual.pdf nothing on 731. Try removing the battery for 10 min to reset all. May be time to replace.
May 02, 2014 | Omron HEM 780 Automatic Blood Pressure...
Error code EE or E
Check your user manual, there should be a section on error codes. Most often E or EE errors are leaking cuff or improper use.
Aug 16, 2013 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Ee 16
http://manuals.harborfreight.com/manuals/67000-67999/67212.pdf
Jul 25, 2013 | Oregon Scientific Wrist Blood Pressure...
An "E" Readin
E is cuff not applied correctly
EE is cuff not inflated properly
E
E
over each other is too much inflation if inflated manually
See page 25 of the manual.
You both need to sit down and read the instruction manual :>)
instruction manual - Omron
https://omronhealthcare.com.au/pdf/SEM-1_Instruction_manual.pdfThe SEM-1 Automatic Blood Pressure Monitor is intended for home use. SAVE THESE ... If the battery fluid should get in your eyes, immediately rinse with plenty of .... These situations could lead to higher blood pressure reading due to strain or the arm cuff ... If an error symbol "E" or "EE" appears, measurement was not.
Nov 06, 2017 | Walgreens Blood Pressure And Pulse Monitor
What does EE mean?
EE means one of 3 things:
1. Cuff has been placed incorrectly. Solution: Wrap the cuff properly so that it is positioned correctly.
2. Did you talk or move during measurement? Solution: Measure again. Keep wrist steady during measurement.
3. Shaking of the wrist with the cuff on. Solution: Same as # 2.
Jan 25, 2011 | Walgreens By HoMedics Automatic Wrist...
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
Reading EE
The cuff sensor must be placed directly over the vain. This takes practice.
Feb 01, 2009 | Homedics Deluxe Automatic Arm Blood...
Only blood pressure result I get is 'EE'
That either means you are moving, or you are inflating the cuff to soon after turning it on. Either of these is what mine means when I use it.
Jan 18, 2009 | Omron Auto Bp Monitor with Easy Wrap Cuff...
Homedics Automatic Arm Blood Pressure Monitor () Logo
890 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
