Question about Health & Beauty
I need plumbing specifications for the Avant Backwash shampoo system chair model 5569brw
3 Suggested Answers
Coastsider
  • 331 Answers
SOURCE: Need to know how to backwash the pool filter
Send pictures of the valve assembly to info@coastsideservices.com and we will try and assist you with your need.
Posted on Apr 14, 2010
  • 8404 Answers
Depends ...
There are two primary valve styles ... a "multi-port" and "push-pull". Never change a valve setting with the pump running.
Multiport has a handle that goes around in a circle (only move it clock-wise). You should go to your pool place to identify this kind of valve and get new lables. Push-pull goes up and down. Up is filter - Down is back wash.
If you will study your system, some things will become evident to you .
Your pump pulls water from the pool through the pump ... out of the pump into the filter. Through the filter, back to the pool. You might be heating the water (would be after the filter) and you may be adding sanitiser (after the heater). One suction - two discharges (oh, the other discharge is to waste.).
Recap ... water out of the pool into the pump - out of the pump throuth the control valve to the filter - out of the filter to the heater then to the sanitiser then back to the pool.
Any help?
Thanks for your interest in FixYa.com
BTW ... I am a volunteer question catcher at FixYa.com. At my job, among other things, I am a Certified Pool Operator (CPO), certified by the National Swimming Pool Foundation.
Posted on May 16, 2010
The shampoo is dispensing too much shampoo, it is empty in no time
Hello There,
Is your machine use the water from the tank at all? If your machine use too much shampoo, my guess is it use less or no water at all. In this case the pump is sucking very little or nothing from the water tank and it does from the shampoo tank.
Please look the attached plumbing diagram. After you opened the unit up, you can follow the tubes and clean the system (solenoid valves but mostly the tubes those involved in the water tank circuit)
Good Luck with the repair!
Sorry, I wasn't able upload!
Sep 10, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
BHR170 backwash port
When backwash is done it dumps to waist, down the drain just like your toilet
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
My pump is on filter but is draining the water out please help
The water Has to be going out the 'backwash' or 'waste' line.Either that or you have a leak in the plumbing. If the backwash/waste valve is set in the 'filter' position and there is still water escaping through the backwash/waste line, it means that the o-ring or spider gasket needs to be replaced or re-seated. If it is a multi-port valve (one that you spin to select the setting as opposed to a 'push/pull valve) you can try shutting off the pump; do a complete turn, 360 degrees, from the 'filter' setting all the way back to the 'filter' setting. This sometimes helps the spider gasket re-seat
Nov 27, 2010 | Intex Wet Set 300 GPH Swimming Pool Filter...
My Hayward Swimpro Sand filter is not backwashing
Be sure it is not plumbed backwards and be sure you got a sand valve as a DE plumbs the other way.
Jun 25, 2010 | Hayward SAND FILTER, PRO SERIES
Mar 23, 2010 | Pool & Spa
How to attach the drain assembly, in a backwash
you could try a sealent from your local hardware store ask the people there tell them your situation and they will tell you what you need
Oct 29, 2009 | Moen 22174 Basket Strainer with Drain...
How do I download Google toolbar for Avant Browser?
You can download Google Toolbar from http://www.google.com/toolbar/ie/. I don't see any specific version for the Avant Browser. However I did notice this post regarding problems and possible solutions for the combo. http://en.allexperts.com/q/Windows-XP-3282/Google-tool-bar-Avant.htm
Sep 20, 2009 | Microsoft Windows XP Professional
Hayward pool motor shuts off in backwash mode.
Check the pump suction filter? To backwash it, is to
open the backwash tank cleanout valve, to clear the dirt out. If this does not work, check the pipelines going to the backwash tank for clogged lines.
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Hayward vari flo filtering system
Check to make sure the plumbing is in the correct inlet/outlet on the valve head. Sounds like it's plumbed backwards. Inlet is from the pump, out to pool...
May 10, 2009 | Hayward SAND FILTER, PRO SERIES
Just bought a used hayward filter,about 4 years old need diagram.
Line from skimmer connects to front of pump, top of pump connects to inlet of filter and outlet of filter goes to pool returns. Inlet and outlet of filter should be marked on filter and most Hayward filters that use backwash valves have valves that come pre plumbed to fit filters. Hope that helps, with pictures or models of filter and backwash valves that's about all I can tell you. God luck
Apr 10, 2009 | Pentair Challenger High Head 1.5 Hp Pump...
Health & Beauty Logo
240 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
