Question about HP Officejet 5610 All-In-One InkJet Printer
How do I put the ink cartridges back into the printer?
    Problem Solver:
  • 6 Answers
How do i put in ink on 926 dell photo scanner and copier
From the online manual...
1. Turn on your printer.
2.Lift the printer unit, and then position the scanner support between the tabs to hold it open.
3.The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4.Press down on the ink cartridge lever to raise each ink cartridge lid.
5.Remove the old ink cartridges.
6.Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
9. Snap each lid closed.
10. Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
Manual can be downloaded here.
Oct 30, 2012 | Dell 926 All-In-One InkJet Printer
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
Error Oxc18a0001 System will not let me print says original cartridge bl., lt.bl. (just replaced), red, yl., need replaced but when checked still have lots of ink in them. & keep getting flashing...
Follow this steps..
Reminder before troubleshooting ...
Make sure that the printer is on. Make sure that you are using HP genuine ink cartridge. Be careful of cleaning the inks and touch w/ your fingers, its very sensitive!
Solution #1 Clean all the inks
  1. open the cartridge access door.
  2. take out all the inks that you have on the printer. (put them on the table upside down)
  3. get a wet clean cloth.
  4. on each cartridge you need wipe it out the electrical contacts on the ink cartridge it self.
  5. put the inks back in to the printer.
  6. close the cartridge access door
  7. turn off the printer
  8. unplug/disconnect the power cable
  9. wait for 1min.
  10. plug the power cable back in back in to the printer.
  11. turn on the printer.
  12. access the setup menu (press the wrench icon on the printer or setup button)
  13. Go to tools, then look for clean printhead
  14. align the printer.
Solution #2 Clean the printhead manually make sure that the printer is on.
  1. Open up the cartridge access door
  2. Take out all the inks that you have on the printer. (put them on the table upside down)
  3. Once you have take out the inks.
  4. Take out the printhead (printhead is the one that holding the inks)
  5. look for the printhead latch. (pull it up)
  6. Take out the printhead.
  7. Clean the electrical contacts of the printhead using a wet clean cloth again.
  8. Put the printhead and the inks back in to the printer.
  9. Close the cartridge access door.
  10. turn off the printer
  11. unplug/disconnect the power cable at the back of the printer.
  12. wait for 1min.
  13. plug the power cable back in to the printer
  14. turn on the printer.
  15. repeat cleaning and aligning the printer by going to tools under setup menu (wrench icon).
If you still having issues w/ it call HP printers support department 1-800-474-6836
Good luck! :)
Jan 31, 2011 | HP Office Equipment & Supplies
The colour ink cartridge is not being identified. I have tried taking them out and putting them in again. I have powered it off and on but nothing is working. Any suggestions would be greatly appreciated
Are you using Dell Series 5 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
Jan 09, 2011 | Dell 924 All-in-One InkJet Printer
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
How to clean cartridge
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer's option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
If you want to go further:
  • Remove the tank.
  • Connect a hose directly on the inlet ink.
  • Locate the sensor of reservoir and press it to make as if a cartridge is available.
  • Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
  • Replace the tank up and do a test print.
  • Repeat the procedure several times if the nozzles are clogged.
Using a syringe and some alcohol to unblock the holes can also be very effective.
  • Step 1: Remove the cartridge from the computer
  • Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
  • Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
  • Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
  • Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Apr 03, 2010 | Lexmark Inkjet Z517 Photo Printer
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Missing black ink cartridge
Unplug the printer from the wall. Also remove the power brick for 60 seconds. This will reset any error messages you get from the printer. Plug everything back in and power on the printer. Take out the Dell black cartridge and reseat it. Put it back in and do the same for the color cartridge. When you close the printer it should try to print an alignment page.
Aug 11, 2009 | Dell A960 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
