Question about Belkin (F5D7633UK4A) Wireless Router
I have one laptop that is connected to the internet...but i have a new laptop to get connected but i cant remember my passphrase
  • 20 Answers
You may need to reset your router by pressing the reset button (usually a very small hole in the back) then you can log in using the default password/username.
Posted on Mar 22, 2011
I cant get wifi connection on my kindle hd
Step 1: Remove any old connections in the Tablet by Long Press Forget Connection
Step 2: Reboot your Wireless Router
Step 3: Attempt to connect again
Step 4: If this fails, log into the Wireless router and charge the authentication mode from whatever you have now to WPA Personal and enter a Passphrase you can remember
Step 5: Connect to your Wireless using the new Passphrase
Apr 07, 2013 | Amazon Kindle Fire HD
Cant connect laptop to router
The passphrase can be seen on the router's Admin page or its usually called router's Setup Page. You can open the router's setup page using your Internet Explorer. First you must your default gateway address. Connect your computer wired to the router or you can use a computer that is hardwired to the router to check the Default Gateway by going to Command Prompt then type IPCONFIG. If you see the Default Gateway, that's the address that you need to type on your Internet Explorer like http://192.168.1.1. If you have the router's setup page opened, you can see the passphrase on Wireless tab or Wireles Security Mode
Oct 22, 2009 | Computers & Internet
Just bought a new lap top have a wireless router on my PC but want to connect to the internet on my new lap top which is wireless enabled, it has picked up the router which is still named as default but...
From your PC (not your laptop):
Click START
Click RUN
Type CMD and press ENTER
Type IPCONFIG and press ENTER
Find the line stating "gateway 192.168.xxx.yyy"
Start Internet Explorer
Type http://192.168.xxx.yyy
Login to your router
Click the "wireless configuration" button
Set a new security-key or passphrase.
Now, try connecting wirelessly from your laptop, using the new security-key or passphrase.
Sep 19, 2009 | Computers & Internet
I need security key/passphrase
Log into the management council on the router. From there, you can find or replace your passphrase.
open your web browser; and type in this address, be sure to use the dots: 192.168.0.1
You will be guided to a login screen. the username is ADMIN (not case sensitive).
The password is blank...that is, do not type anything in the password box. Hit enter.
Good luck
tony
Jul 02, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Security key/ passphrase
The easiest workaround for this is to connect your laptop to the D-Link
with an ethernet cable.
Make sure your laptop IP address is configured for the same subnet
(example: 192.168.0.9)
Open your browser and go to http://192.168.0.1
Default username: user
Default password: (blank)
(This is of course assuming that you did not change your
default username/password)
Once you're in, change the passphrase to anything you want.
Jul 01, 2009 | D-Link DI 514 Wireless Router (DI-514)
Wireless passphrase on my laptop
try your phone number call att or review paperwork. it should say or they will know
Jun 01, 2009 | Dell Inspiron 1525 Laptop
Message when I try to connect wireless is I need
Check your router configuration under some sort of Wireless Encryption option. Essentially you or someone else set up a "passphrase" on that router which created either 64-bit or 128-bit encrypted keys from that phrase. You'll most likely find this passphrase under the Encryption information.
Mar 05, 2009 | Westell Wirespeed VersaLink...
Connecting to woreless internet connection
Be sure you use same security protocol on your PC than in your WLAN:
WEP or WPA or WPA2 protocol
Passphrase (PSK ) or Password
TKIP or AES.
Use same Key.Passphrase on your notebook as in your Access point.
Check if your Access point/router has access list enabled: either you disable it in your AP either you add your PC MAC address to the list.
Dec 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
I have a D-Link wireless router, it is a DI 524 model. Well I just recently had to reinstall everything on my desktop computer, which my wireless router and dsl pipe are hooked up to. I have a laptop with...
IF YOUR WIRELESS NETWORK ACCESS POINT IS CONNECTED BUT YOU CANT GET ONLINE,YOU WILL NEED TO GO TO YOUR DLINK ONLINE ROUTER SETTINGS PAGE AND CHANGE YOUR PASSPHRASE KEY WHICH YOU NEED TO CONNECT THE ACCESS POINT TO THE WIRELESS ROUTER.BEFORE YOU DO THIS THOUGH,OPEN UP THE NETWORK CONNECTIONS WIZARD ON YOUR LAPTOP AND VIEW"AVAILABLE WIRELESS NETWORKS".IF YOU SEE YOUR NETWORK LISTED,HIGHLIGHT THE NETWORK AND PUSH THE CONNECT BUTTON.WINDOWS WILL ASK YOU FOR A PASSPHRASE OR PASSWORD.ENTER THAT AND CLICK CONNECT.YOU SHOULD THEN GET CONNECTED TO THE WEB.IF YOU DONT HAVE A PASSPHRASE OR PASSWORD,THAT IS WHY YOU CANNOT CONNECT THRU THE ROUTER AND YOU WILL THEN NEED TO CREATE A NEW PASSPHRASE AT THE D-LINK WEB SETTINGS PAGE.GOOD LUCK.
Aug 22, 2008 | Computers & Internet
I have wireless router and my laptop will no longer connect to the internet. The computer says wireless networks are available, but when I try to connect it asks me for my security key or passphrase. It's...
Maybe provide the brand of router.. Anyway, I have lost my details as well, several times over the last couple of years.. It's just a case of accessing the router (via web browser, using the correct IP address for your brand of router).. Then you can delete the existing network & add a complete new one. You get to use a new key & passphrase. If you need further help, please provide your router brand & model. Rgds, dave
May 02, 2008 | Computers & Internet
Belkin (F5D7633UK4A) Wireless Router Logo
41 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
