Question about Microwave Ovens
I have a whirlpool mh8150xjq-1 microwave. it was manufactured in 2002. Recently, it started sparking from the rack hook- only one. it would do this intermittenly until it started doing this more often and caught on fire. I removed it with plyers- is that ok?
MicrowaveSvc
  • 9098 Answers
SOURCE: arching microwave oven
The area that has arced needs to be cleaned thoroughly, and if the paint is affected, it will need to be sanded smooth and cleaned with alcohol.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If the rack support is charred or melted, it will need to be replaced. It's best to replace them as a set.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 06, 2008
mumma_1
  • 903 Answers
SOURCE: Yam caught fire in microwave
If you have given the microwave enough time to cool off and it still does not work then I would suggest that you would need a new one, as the circuit board may be fried that connects the control panel.
Posted on Jan 15, 2009
SOURCE: micowave sparks a fire
I had the same exact problem. My clips arced when I ran the unit and I also observed flames which was quite unsetteling. A work around for me, since I don't use the rack was I took it out then removed the clips. All that was required to remove the clips was a pair of plyers grabing each cliip at their base. I pulled firmly and there is alittle resistance but with a firm pull straight out they'll pop out.
But I have to say if you use rack your probably looking for a new mircowave.
Posted on May 03, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave mica board sparking
That's the waveguide cover, a critical part of the oven.
This arcing is usually due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
You can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Posted on Oct 30, 2009
SOURCE: Fire in Frigidaire Electrolux Microwave PLMV168CC1
Turned on high empty for 20 minuets
Posted on Sep 19, 2010
Is it safe not to replace the plastic support clip in the microwave mine has melted twice. I don't want to use the rack.
I wouldn't plan on using the unit either. Sounds like nothing but trouble. Contact manufacturer.
Feb 16, 2015 | In Microwave Ovens
My Kitchen Aid Microwave Model no. KHMS155LBL 0 has a broken rack support hook on one side. There are four hooks which snap into a square hole on each side of the microwave cabinet to allow the...
The part you're looking for is Whirlpool number 8204662. Several sources came up from a Google search. Here's one. I've never done business with this site, but their price was the lowest of several I looked at.
Apr 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My microwave was manufactured in 1984. just recently started shooting out sparks? Do I need a new one. Doesnt work well
Sparks are a bad thing - I would go new or used from Craigslist. Just check that it works. GE performance test: Heat 1 liter of water for 2:03 at full power, should raise by at least 35 degrees @120V. Record starting temp and ending temp (no cooler than 59 to start).
Nov 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
F7 code on Whirlpool Microwave model GH9185XLT - 1
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
May 23, 2017 | Whirlpool GH9185XL Microwave Oven
Sparks and Flames in my Kenmore 66561652100 Microwave
usually the only thing i'm aware of that will do that is if there is some kind of metal object in the microwave when you cook... even plates with thin painted metalic bands on the cause that affect.
remove the hook... place a container filled with water inside the microwave for about a minute to aid in cleaning... and examine the hook for any metal.
Mar 23, 2009 | Kenmore Microwave Ovens
Micowave sparks a fire
Dec 27, 2008 | Whirlpool MH1150XMQ Microwave Oven
Arching microwave oven
Sep 03, 2008 | Whirlpool Microwave Ovens
Whirlpool microwavewave hood comination mh3184xp
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
Feb 04, 2008 | Whirlpool MH3184XP Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
