Question about LG VOYAGER VX10000 Cellular Phone
I just activated a refurbished lg and it is my second one from the company same problem when I dial a number and press send the phone restarts but will send txt messg
  • 79 Answers
I had this same problem with my old phone. I had to take it back and get them to reinstall the firmware, and OS. One time when I went in they said that they did not have the equiptment to do that, and just gave me a brand new phone, and the second time they fixed the problem on the spot.
Good Luck!
Posted on Mar 22, 2011
How to increase the no. of rings on my LG tracfone
  • Press *#61# on the phone's keypad and press "Send."
  • Write down the phone number that is displayed, because it may be different than your cellphone number. This screen should also display the number of seconds your phone is set to ring before going to voicemail. Press "Cancel" to return to the main screen.
  • Press *61 followed by +1 and the 10-digit number from the previous step. Do not press "Send" yet.
  • Press 11 followed by the number of seconds you want the phone to ring, such as 20 for a 20-second ring time.
  • Press # to finish the sequence and press "Send." Your settings should now be changed. You can dial *#61# and press "Send" to check the settings.
Jun 17, 2016 | LG Cell Phones
HOW TO CALL FORWARD TO CELL PHONE NUMBER
There are a couple of ways to achieve this.
First, press 355 on your phone to activate the call forward feature. Once it asks for a forward destination, press whatever number your company uses to dial an outside line. After that dial your number like normal and hang up the phone.This will forward all calls directly to your cell phone.
The second method is the same as the one listed above but it uses the feature code 356. 356 will forward calls if you do not answer from your Mitel phone first.
I hope this helps
Sep 03, 2014 | Mitel 5330 IP Phone
Want to know how we can divert our Panasonic KX-T7730 to a mobile number
What you want to do is to activate the call forwarding feature offered by your phone company. Different phone companies have different procedures. With many companies you dial *72 then at the second dial tone dial the number to forward to. This number has to answer the call to activate call forwarding.For precise instructions please contact your telephone company.
Apr 25, 2012 | Panasonic KX-T7730 Corded Phone
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
How do you 3 way call on the LG vu. when i call the third party with the other person on hold it wont let me join them.
  1. While on the first call, dial the 10-digit number of the second person.
  2. Press SEND; the first person is automatically put on hold while the call is made.
  3. When the 2nd person answers, press SEND to create a conference call.
  4. If the second person does not answer, press the SEND key twice to end the connection and go back to the first person.
  5. To end both conversations completely, press the END key.
Jun 15, 2009 | LG Vu Cellular Phone
Samsung SGH-D807
  1. On your phone, dial *#61# and click Send.
  2. Some information should be displayed: number that the calls are being forwarded to and the delay before the forwarding engages.
  3. Write down the number (including +1)
  4. Dial **61*+1xxxyyyzzzz*11*30# and hit Send. +1xxxyyyzzzz is the number you wrote down previously, 30 is the delay in seconds. The delay can be set in 5 second increments, 30 is maximum
  5. Dial *#61# to verify that the new settings are active.
Feb 03, 2009 | Samsung SGH-d807 Cellular Phone
Voicemail box not set up
I have seen the same problem with some users (I look after the PABX) so I just go into the maintenance console and set up the foreward to the default voice mail number. Or you can try the following:
CALL FORWARDING HANDSET 1. Press the Speaker Phone Key on your handset 2. Then Press the FWD/DND Key 3. Then select the Forward type you desire - Key 2 - Immediate Key 5 - Busy/No Answer 4. Then dial the internal extension number (eg.444) or voicemail pilot (201) 4a. If forwarding to external number dial 0 then dial outside telephone number 5. Dial # then press the Speaker Phone key
Use the voice mail that is set for your system.
Hope this helps
Jan 08, 2009 | Panasonic KX-T7630 Corded Phone
Forgot my lock code
The default lock code for any Verizon Wireless phone is the last four digits of your phone number. If you've changed the lock code, then you have two options:
1. LG phones can be reprogrammed even when locked, so dial *228 and press Send. When you hear the woman's voice choose option 1. When the call ends the phone will reboot and your lock code will be changed back to the last four of your phone number.
2. Bring the phone into a Verizon Wireless store, where they can read the lock code off the phone using their computers.
In the case of the original poster - if your phone isn't activated at all, as in it is not currently active on any phone number, then go with the second option. You could, if you really wanted to, call Customer Service and have them put that phone onto your phone number, then when you activate it (*228, send, option 1) the lock code will be the last four of your phone number.
Sep 26, 2008 | LG VOYAGER VX10000 Cellular Phone
Cannot activate dial pad
Do a hard Reboot, Turn your phone off and wait 10 secs then turn it back on it should be fine.
May 03, 2008 | LG Prada KE850 Cellular Phone
LG VOYAGER VX10000 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
