Question about Yamaha IM824 24 Channel Mixing Console IM8 IM8
I have a Yamaha IM8. I had a condenser mic hooked into channel one with phantom power on. I had to leave the room for a while and when I came back, I noticed some rather severe popping in the audio. I turn off the phantom power, change to a different condenser, turn phantom back on and this mic will not pass any audio. I turn off phantom power, connect a dynamic mic and I do get audio. It sounded raspy at first, but soon smoothed out. The power supply indicates that it's 48 volt output is fine. The first condenser mic may have problems like a flaky connection across the phantom circuit. Hope the board's not damaged. Whats the word on that? Thank You.
  • Yamaha Master
  • 5,603 Answers
There is really no way for a condenser mic to damage the board UNLESS you break the ground and get a static discharge into the input. That can happen with any microphone and has NOTHING to do with the phantom being on or off. As phantom power goes on and off slight bias at the input preamps can make amps non-linear causing the raspy sound you heard. The Phantom LED means NOTHING as it shows the state of the phantom switch by connecting a 12 volt source through a resistor to the LED... It shows NOTHING regarding the state of the 48 volt supply. Each input circuit has two 6.8Kohm resistors to the swinger of the phantom switch 2nd pole that either grounds those or connects them to a filtered 48 volt source. As long as you don't have a static buildup there is NO need to turn phantom power on or off while connecting a condenser microphone. At each input when using the XLR jacks are two per side 470pf capacitors for RF bypass. For the XLR's there is a 10Kohm between the signal lines and two series 10mfd/50 volt caps in series of each input to block the DC, when using phantom power, from reaching the preamp stage. These caps have to charge and discharge when changing the state of phantom power so you should AVOID having the main amps being driven while changing the state of any phantom power. Always have the fader(s) down and any monitors down to avoid a thump and also the non-linear raspy transition as the input caps charge/discharge. So fix the microphone... don't know what type you have, but DO check the cable (first) as ALL three conductors MUST be good for a condenser mic to work on phantom power. A ground leakage or noisy connection will cause your symptoms. Use a SHORT known good cable right at the board to test the mic. The 48 volts is applied through the two 6.8K resistors between both the signal lines to the shield of your XLR cable. The microphone picks off the 48 volts with a similar circuit.
Now let's cover a very important thing regarding system safety: ALL, and I do mean ALL interconnected equipment MUST be powered from the same source. Professionals run a power cord back to their mixer right alongside the snake. This is to avoid ground bounce damage due to bad building grounds or ground faults.
Posted on Mar 22, 2011
I had major static sounds from my yamaha stagepas 500. I plugged in an acoustic guitar into the mixer while running a keyboard and 2 vocal mics. I started getting crackling sounds. I changed the patch...
Chances are there is nothing wrong with the mixer. IF you accidentally turned on Phantom power, that would cause the problem. Phantom is ONLY used with condenser mics and a few DI boxes. Turning it on can create noise unless balanced lines are used everywhere.
Jun 29, 2011 | Yamaha EMX512SC Powered Mixer 500 Watts...
When the phantom power is on, some channels decide to come and to. Particularly with the SM57 mic
Don't know what you are saying. Phantom power is only used for Condenser mics and a few DI boxes. Make sure you ONLY use TRS or XLR cables into ANY/ALL inputs when using Phantom power. Please describe what you mean by :some channels decide to come". ONLY change Phantom power when system is off as you will get loud noise often by switching phantom while live.
Jun 07, 2011 | Behringer XENYX 2442FX Mixer
I have Lexicon alpha, Condenser Mic, phantom power .If i record, the voice goes only to right speaker. I am using cubase le 4, stereo in/out are correctly.
Sorry, but the Lexicon Alpha does NOT have Phantom power and you can't use a condenser mic with it without a Phantom power injector or preamp.
If you mean you have a Phantom power injector then it should be working. Do you have seperate mics for the two channels of the stereo? If you have only one mic, then only one side will record unless you set for mono recording and then dump the recording into stereo voa Cubase. I would recommend you get a small mixer... even a 4 channel one to use ahead of the Lexicon so you can mix and PAN your mics the way you want them. The recording and trying to control the panning in Cubase can be frustrating... The Lexicon really doesn't have anything built in to PAN the mic to the center when stereo recording. Small mixers are inexpensive and often you can find them used or in pawn shops for cheap.
Feb 12, 2011 | Lexicon Alpha Personal Recording Studio
I have a lexicon alpha, samsung CO1 condenser mic and a samsung phantom power box, i have all the correct wires but i dont think i am connecting the correctly, HELP ME ! lol
Sorry, but the Alpha does NOT have Phantom power which IS required for a condenser mic.
You will either have to get a mic preamp that supplies phantom power or go to a dynamic type mic if you stay with the Lexicon Alppha.
Jan 17, 2011 | Lexicon Alpha Personal Recording Studio
Presonus studio channel has no sound
Assuming you are connecting a microphone to this, if the mic is a condenser mic, make sure you have Phantom power on the PreSOnus turned on. You have given us almost no info of your configuration of mics and other devices connected to this unit.
Dec 26, 2010 | PreSonus Studio Channel Tube Channel Strip...
Im having a problem with hearing my b-1 studio condenser mic on the lexicon alpha progam?
Sorry but... Very simply, you CANNOT use a condenser mic with the Alpha since it does not supply the required Phantom power for the mic. You must step up to another interface to use condenser mics. You can use dynamic mics with the Alpha or other audio sources. I use a Roland/Cakewalk UA25E interface with condenser mics and also the Lexicon Omega which does have Phantom power for the mics..
Nov 03, 2010 | Lexicon Alpha Personal Recording Studio
Have just purchased lexicon alpha to use on a Mac. Having trouble just getting started. Have hooked up a nice condenser mic into the alpha through the mic input on the rear and cannot get anything on the...
Make sure you have Phantom power turned on on the Lexicon... Oh,oh... it appears that the Alphs may NOT have phantom power which IS a REQUIREMENT for most condenser mics...
The Lexicon Omega does have this but apparently the Aplpha doesn't have it.
That leaves you with the choice of either getting a dynamic mic that doesn't need Phantom, or replacing the Alpha, OR using a preamp ahead of the mic before the Alpha...
Sorry, but those are the only solutions I see for you.
REMEMBER that condenser mics pick up everything and you cannot run them into a PA or they will feedback.
Oct 08, 2010 | Lexicon Alpha Personal Recording Studio
Wound the yamaha MG102c be good for a small duo or solo
The mixer is strictly a mixer. You would need to amplify to drive speakers. Used as a mixer it is fineand would support up to 4 mics.
It does have phantom power for use with condenser mics if needed.
Please use balanced lines (TRS) when connecting to the external amp.
Apr 21, 2010 | Yamaha Mg102c Stereo Mixer
Not working
If it is brand new, it is likely "pilot error" as setting these up if you are unfamiliar with mixers can be frustrating.
There are several things that must be done to have a working system. Correct speaker cables are one and the setting of all the knobs are important...
DO NOT REPLACE FUSE. If any LED's are on, fuse is OK. If fuse blows, service the unit before replacing fuse to avoid further internal damage.
Make sure speaker cables are good.
Set the level control for the channel you are testing up AND you may need to press the "PAD" button to change the input gain. Turn up the master gain.
Depending on the source you are using, line or mic you may need to change the PAD button.
NOTE: This mixer does NOT have Phantom power and cannot be used with CONDENSER microphones requiring phantom power. You will get no audio from a condenser mic without phantom power. You must use dynamic mics with this mixer.
Jun 12, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Yamaha IM824 24 Channel Mixing Console IM8 IM8 Logo
145 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
