Question about Uniden BC60XLT Handheld Scanner
Manual programming my scanner
I push the Manual button and then enter the Freqancey and then push Manual again and it shows "Error" why does it do that? thanks
Push the manual button and then enter the frequency number for the channel showing then push the E button.
Posted on Aug 23, 2008
Help programing a realistic pro 2010 scanner
  • Hi, here is the users manual http://www.racingelectronics.com/files/bc80manual.pdf Page 14 tells you how to program your scanner. You have to throw at least one frequency in the scanner before it will receive anything. I can get you some for your area with a state and city.
  • As for programming follow these steps.
  1. Press the manual button.
  2. Now pick what channel you will enter a frequency on by pressing on the number key pad.
  3. Now press the manual button again
  4. Now enter the frequency you want to program.
  5. Now press the "E" button to enter it.
  6. That's it, do it again until your scanner is full.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thanks for using FixYa.
Regards, Tony
Sep 19, 2011 | Uniden BC80XLT Handheld Scanner
How to porgram bc140police scanning radio
First, you'll need a list of frequencies to program into the scanner. The BC140 memory is limited to just ten channels, so you'll need to select your coverage carefully. For a detailed database of active frequencies in your area, visit:
www.RadioReference.com
Once you have your frequency list:
- Power the scanner ON.
- Press the Manual key to stop scanning.
- Select the channel to program (1 through 10) by either entering it on the keyboard and then pressing Manual again, or by repeatedly pressing the Manual key to advance through the channels.
- Enter the frequency, including the decimal point (e.g., 156.055).
- Press Enter (E) to save the frequency in the scanner's memory.
- Press Manual to advance to the next channel and enter your next frequency.
When you finish programming, press the Scan key to start scanning.
If you enter an out of band frequency, one that is not covered by the scanner, the display will show E for error.
Bill B.
Listening in since the 60's
Nov 01, 2010 | Uniden Radio Communications
WHERE TO FIND CODE MANUEL
Hi.
To program the scanner do the following:
  • Press "MANUAL" button. The display will show the channel.
  • Keep holding the "MANUAL" button until the display indicates the desired channel.
  • Press the "E" button.
  • Enter the channel frequency.
  • Press the "E" button again. The frequency is now programmed for the channel you selected.Verify that your entry is correct by pressing the "REVIEW" button.
Here the reference guide: Reference Guide
Jan 14, 2010 | Uniden BC248CLT Base Scanner
How do you program a bearcat bc55xlrt scanner with a code?
There are no codes, only frequencies. For a comprehensive database of active frequencies in your area, visit:
To program your BC55XLT:
Turn on radio.
It will be in scan mode. Press Manual (orange button) to stop scanning.
Press Manual button to step through channels to get to the one you want.
(Or press channel number and then manual button)
If "LockOut" is displayed it means this channel isn't being "Scanned."
You will want to lock out constant "broadcast" services such as NOAA or airport weather. Pressing Lockout will toggle the feature on and off.
Select a channel to program. Use the keypad to enter frequency. Use "E" for Enter
key. If the radio displays an E this means Error. Usually, the
frequency you typed in is outside of the capabilities of the scanner.
Once you hit the E you will immediately start hearing anything that's
out there on the frequency you entered.
Push the "Review" button and the scanner will display the frequency
that is programmed for the channel. A "-" will be displayed for the
decimal point.
Jan 12, 2010 | Radio Communications
I need to know frequencies and how to program a bearcat 148xlt
To program the Bearcat 148xlt, press the manual button and then enter your code, for example:"123.456" after you enter the code, push E and then press the manual button again to enter a new code like "567.987" then press E, when all of your codes are entered press the scan button to finish. Try http://www.scannermaster.com
or http://www.radioreference.com for some frequencies to add to your scanners database
Dec 16, 2009 | Car Audio & Video
How to program regency model 1070 scanner? I program scanner,yet unsure why no ''frequencies'' stop.Only zero flashes>
I couldn't locate a manual for you, but this vintage 10-channel unit is fairly simple to operate.
Start by turning the unit on with the POWER button.
Push the MANUAL button.
Push MANUAL until you see the Channel you want to enter the frequency in -i.e: Ch 1, Ch 2, etc.
Enter the frequency with all the digits needed - i.e: 44.94 / 44.98 / 154.965 / 155.610 etc
Push the ENTER button. The frequency will now be in the Channel "Ch" you chose.
While still in the manual mode - go the the channel you expect to listen to most - then push "DELAY/HOLD". This will hold the scan so you will get the reply from the dispatch unit to the receiving unit.You can set this feature on any or all of the ten channels.
Push the "LOCK" button to lock out channels you no longer want to listen to, or that you want to ignore temporarily.
Dec 09, 2009 | Radio Communications
How do i program my BC 55xlt uniden scanner?
To program:
Turn on radio.
Pressing Lockout will toggle the status.
To program:
Select channel. Use keypad to enter frequency. Use "E" for Enter
decimal point.
Dec 04, 2009 | Uniden Radio Communications
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Coverage:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)
Nov 07, 2009 | Uniden BC248CLT Base Scanner
How to install new freq in a Uniden BC 560XLT
For the BC 560 XLT, choose "MANUAL" mode on front of scanner. Push the manual button until u reach the number you want to program on your scanner ( 1-16) press the "E" button or "Enter" enter your number i.e. 555.555 in the six digit format with the decimal after the first 3 (industry standard) than press the "E" or "Enter" again. You're done. Hit scan or if u want you can press "REVIEW" to double check your number. Works the same for all numbers or if you want to replace a frequency with another.
Jul 09, 2009 | Uniden Radio Communications
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Feb 19, 2008 | Radio Communications
Uniden BC60XLT Handheld Scanner Logo
95 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
