Question about LG WM2487H Front Load Washer
LG 2496HWM is leaking a considerable amount of water onto the floor. Appears to be coming from underneath unit
    Guru:
  • 262 Answers
When is this leak happening? During what part of the program?
Open the bottom front lower door. This is where the filter is located...the filter is attached to the drain pump.
While this is open see if you can see where the leak is coming from.
Unscrew the four screws that hold on the back panel.You will need a light to see inside of the unit. See if you can locate the leak from there.
Use two people to spot check...one in the front and one in the back.
You should be able to see where the laek is.
Please post results.
Keith
Posted on Mar 22, 2011
Water leaking onto the floor after flushing
check around where the tank meets the bowl and see if water appears when you flush and if so you need a new tank gasket. If it's coming from where the toilet meets the floor you will have to change the wax seal underneath. That happens when the toilet rocks and ruins the wax gasket.
Oct 08, 2014 | Home
Water runs out the frezzer side when the door is closed onto the household floor.
Look underneath the fridge and check the drain pan it's probably full. Also check your hoses when you under there. You have a line running from the wall underneath the fridge and up to the water supply system. Check for any lines that might be leaking or have come loose and causing the problem.
Dec 22, 2010 | LG LSC26905TT Side by Side Refrigerator
A small amount of water is leaking out of the front of the refrigerator onto the floor every day and I can not fine the source of the water. Is there a drain pan and if so where is it? If it is not the...
older fridges drained water into a pan with the compressor in it, thus cooling the compressor and evaporating the water, this is located at the bottom back of the fridge. if this fridge has a water and/or ice dispensor, the water could be leaking from many a place.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
106.55244400 leaking water on floor
Hello, sounds to me like you either have a leak on the nut on the water inlet valve or a pinhole leak on the inlet valve body...have come across this many times before...you may not see the leak from the valve because it is very fine spray but it's there...only real way to detect where it is coming from is to pull the valve out switch water on and see where the leak is....either this or you have a blocked drain tube in the refridge but with the info you supplied i would suggest the valve. If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Aug 17, 2009 | Refrigerators
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking from the Bottom of the Washer onto the floor
happy new year,,,ready time to go to work..first open the door and see if you have a pin hole in your bellows,,that the big rubber gasket around door.....use a flash light,,next check the dispenser water if pressures to high it will splash over and run down inside of unit,,you wont know until it hits the floor...now greg,,this is a touch hard,,i want you to unplug unit and remove toe panel...there 3 .1/4 in,,screws,,now check your pump,,you have a birds eye veiw of any water marks...im here if you need me..
Dec 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2487H Front Load Washer Logo
61 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
