Question about Epson Stylus Photo 1400 Printer
Hi Ya! I was looking out for the solution of the Epson 1400 printer having black toner shows pop-up message; which displays "Consumables near end of service life". "Prepare the following consumables: Photoconductor Unit". Do let me know the exact solution of the above mentioned problem. Cheers, SACHIN
  • sachin740 Mar 22, 2011
    HI YA!
    Your response was beneficial. I want to confirm one last thing from your end.
    Do you mean that I need to replace a current Photoconductor Unit with a new one? I have used the Epson Offirio LP-1400 Monochrome Laser printer for 2 years now.
    Thank you for your great effort.
    Cheers,
    SACHIN
    Novelist:
  • 107 Answers
If a consumable product reaches the end of its service life, the product stops printing and displays the following messages in the LCD panel or the window of EPSON Status Monitor 3. When this happens, the product cannot resume printing until you replace the depleted consumable products.
The photoconductor unit comes to the end of its service life. Even if this message is displayed in the LCD panel, you can continue to print for a short time by pressing the B&W Start or Color Start button on the control panel. The message in the LCD panel changes from Replace Photoconductor to Worn Photoconductor.
Posted on Mar 22, 2011
  • Lester Mar 22, 2011
    Yes you need to.
What causes a dirty background?
Copied
1) - Power ON printer while holding both the + & - buttons until "OKIUSER" message appears in LCD.
2) - Press + or - button until "ENGINE DIAG MODE" is displayed.
3) Press "ENTER", displayed will be "DIAGNOSTIC MODE XX.XX.XX S-MODE"
4) Press + or - button until "NV-RAM INITIAL" is displayed.
Half way, dont stop too long it will time out....
5) Press "ENTER" again.
6) Will appear "TABLE 1" message.
7) Press "ENTER" until "EXECUTING RESET" message appear. ...............the "NV-RAM INITIAL" message will BLINK.
Tada....This procedure reset TONER, DRUM, FUSER and BELT...life counts
8) power OFF printer, wait 10 sec, and power ON again..
To access Service Mode in C9300 power ON printer with 0, 1, 6, 7 at same time...you can do some good damage in there!! (I warned ya!)
Resetting consumables for OKI C7300,C7500,C9300 printer I think!
1. Hold buttons 0 + 1 + 6 + 7 on startup.
2. Press button 0 several times until "DIAGNOSTIC MODE xx.xx.xx" shows.
3. Hold buttons 2 + 3 until "ENGINE DIAG LEVEL 4" shows.
4. Press button 1 to scroll to "COUNTER SET".
5. Press button 2 to scroll through menu items (button 6 scrolls backwards)
6. To alter the value of an item, first press button 3 to select the digit to be altered. The selected digit will slowly flash. (Button 3 moves to the right through the digits. Button 7 takes you to the left.)
7. Then press button 2 to increase the value of the selected digit. Press button 6 to decrease the value.
8. When the changes have been made hold buttons 1 + 3 + 5. The screen will flash three times and then an * will appear on the right of the screen. The new value is set.
9. To leave the counter set menus, turn the printer off.
IMPORTANT
Each colour toner counter shows life as percentage used. So a toner showing 30% has used up 30% of its toner. 100% would indicate a near empty toner. This is the reverse of the toner life shown from the "usage menu" when the printer is in normal operation, which shows the toners as a percentage life remaining. You will want toner showing 00%. note:this is oposite of what you see in user mode
Some models exhange these steps
3) HOLD 0 + 4 "ENGINE DIAG LEVEL 2" shows
4) Press 1 to cycle to "fuser unit"
5) 2 to scroll to TONER
REST IS SAME WE WANT TO SET WHAT i GUESS IS AT 100% TO 0%.
Jun 10, 2014 | OKI C9600hdn Laser Printer
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Black Cartridge just changed, but still says K-toner low
The only way to clear the message is to wait until the the display shows XXXX Toner Out, then change the cartridge and the message will clear itself.
May 18, 2008 | Epson AcuLaser C4000 Printer
K toner cart out, Epsom C1900 Aculaser color printer
i had the same problem as you i feel very upset with epson that they did not help you for me what i had to do is lay my printer on its side with the door to the toner facing you taking the toner out looking down into the bottom you will see a little plastic block wist it half way till it stops then reinsert the toner becarefull not to drop it in that shoud be fully fitted inside then put the unit back the right side up and start the printer up this shpuld fix your problem ok thanks
Feb 05, 2008 | Epson AcuLaser C1900 Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Black toner low Epson Aculaser CX11NF
Try powering the unit off and on. The toner indicator does not always reset immediately in my experience
Nov 02, 2007 | Epson ACULASER CX11NF All-In-One Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Epson Stylus Photo 1400 Printer Logo
345 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
