Have a calypso elite kenmore washer that will not drain. How do I get the cap to agitator off and how do I clear that line or access the drain line, this is an older top loader.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
The pump is accessed from the bottom. Lean the machine back against the wall and remove the lower panel. You will likely need to replace the pump assembly. The original pump style has been changed.
Kelly
Posted on Mar 22, 2011
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My Kenmore Elite Calypso is displaying the letters LD and will not start.
Assuming this is a WASHER, and not a dryer - LD is an error code for Long Drain.
This means the pressure sensor has not reported the tub to be empty after a certain number of seconds.
Usual causes - due to poor design - are the outlet line strainer being plugged with coins, legos, panties, socks, etc... or the pressure switch (or tubing) failing.
Remove the pump's inlet line (outlet from tub) and check that the line is cleared of foreign objects.
If it is clear - move to the pressure switch. Many times the tubing is cracked - or moisture has developed inside the tube. Remove it from the switch and attempt to blow in the tube.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2010 | Kenmore Elite HE4 Electric Dryer
How to remove the cap on Kenmore Elite Calypso washer
you'll need to access the pump and remove the hoses. Clean the inlet screen.
Mar 16, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Calypso wont drain
Oh the dreaded calypso pump...Seen that one a million times. Pumps get clogged pretty easily. Try to get the water out manually first. Than push the washer back and lean it against the wall so that you can access the bottom. Remove the 3 screws. Bottom panel should come off. The pump is on the right, its black. Get ready with a shop vac or alot of towels, theres gonna be a flood. There are 2 clamps on black hoses that need to be taken off so that you can slide the hoses off the pump. Next remove the 3 bolts that hold the pump in place. Next lower the pump out of the hole it sits in. Youll have to follow the wiring harness up and disconnect it. Now you can try and clen out the pump or replace it. Part # is 285990. Costs about 75.00. Hope that helps. Let me know if yiu need more help. Dave www.washermd.com
Dec 11, 2008 | Kenmore 22422 Top Load Washer
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Calypso Washer agitator malfunction
you either have too much stuff in it or something that gets under
the agitator or it has a weak transmission
Mar 16, 2008 | Washing Machines
Washer gets ld code
The ld fault is a long drain error. Check your drain pump reservoir and drain hoses for clogs. Removing the agitator in my opinion would be unnecessary. Unplug your machine and remove the back panel. There should be a drain pump reservoir at the bottom under the wash basin. They are notorious for collecting lint and hair and can obstruct the drain flow. You can also squeeze along the drain lines and feel for obstructions. To access the drain pump itself, its easier to remove the front panel. You will need to release the two metal hold down clips located under the front lip approx. two inches from either side. You need a putty knife to push in on the clips and lift on the top front at the same time. Once you have the top released, lift up and remove two screws holding the front panel. The front panel should pull away leaving an open access to the inside cabinet. The drain pump is located on the lower right-hand side of the wash tub at the very bottom of the unit. You can easily remove the two drain lines at the pump and check for obstructions there as well. Again, unplug the unit before servicing the pump. I hope this helps.
Mar 29, 2007 | Kenmore 23822 Top Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
