How to reset thin client password
Need to re-flash XPee and I can't find solution from being stuck in User mode. Tried pulling the CMOS battery , load defaults ?
Trying to setup thin client for MagicJack
  • Panhwar Feb 19, 2009
    kindly guide us my terminal BIOS is reset every time on starting of treminal.
Bought a Fugitsu T4020D with a broken screen at a yard sale. Fixed the screen but it is password locked at BIOS, and before Windows loads. How can I unlock the BIOS to get into this thing?
1. Bypass Windows 7 Logon Password with Command Prompt While computer couldn't boot normally or notebook is infected with Trojans or malware, you can get rid of them by starting computer in Windows Safe Mode. Furthermore, when lost or forgot Windows password, you can also bypass Windows 7 logon password easily in Safe Mode.
In Windows 7, there are 3 different types of safe modes to choose, Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt. And the following guide is about how to bypass Windows login password with Command Prompt in Safe Mode. With net user command in Windows safe mode, you can reset Windows password effectively. Details as follows:
Step 1: Start or restart your Windows 7 computer.
Step 2: Press F8 to enter Advanced Boot Options before the Windows 7 loading screen appears.
Step 3: Choose Safe Mode with Command Prompt in the coming screen, and then press Enter.
Step 4: Wait for Windows 7 files loading until Windows login screen comes up.
Step 5: Log in Windows with an administrator account until you see login screen.
Step 6: A Command Prompt appears. Type net user in the Command Prompt and then hit Enter. All Windows user accounts will be listed for you.
Step 7: Type net user iSunshare 12345 and hit Enter.
Note: "iSunshare" is your locked Windows user account name. And "12345" means the new password you want to reset for the locked account. User account "iSunshare" will be reset with new password "12345".
Step 8: The new password has been successfully reset for user when the command is completed successfully.
Step 9: Login Windows 7 PC with the new password.
Whenever you need to access Windows in Safe Mode, an administrator account password is necessary. So it is highly recommended that write down Windows password and store it or creating a Windows password recovery disk before Windows password lost.
May 11, 2016 | Computers & Internet
My desktop PC won't take my password, could it be caused by bad CMOS battery? This computer has not been used for over a year.
The cmos battery holds your password and boot order settings on some motherboards removing the cmos battery will not remove password its held by a small chip which has back up power designed for this
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Jan 16, 2013 | HP Computers & Internet
I forgot my password how can i log on to windows
how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard some motherboards cmos batteries are soldered in
Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased
or if using XP
Restart your computer during the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
hope it helps
Jul 03, 2012 | HP OmniBook XE3 Notebook
Forgot password
or if using XP
hope it helps
May 29, 2012 | HP Mini 110-1037NR Netbook
How CAN I GET TO SETUP TO CHANGE BOOT MEDIA ?
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account. Hope this helps you
Feb 26, 2012 | Computers & Internet
Computer would not booy up. now it does but the password does not work
which operating system ant what type of computer??
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
also
how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased
or if using XP
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.
hope this helps you
Sep 10, 2011 | Computers & Internet
Need to change password but i dont know the old one
i advise you to get on eby and type in Windows Password in the search and get you a copy of any of the windows password reset discs there cheap and it will solve your problem
Dec 08, 2009 | WYSE Winterm V90LE Thin Client - Thin...
I bought a IBM thinkcentre from Circuit City but no cmos password
Best thing to do is take it bake and see if they set it for security reasons and have them unlock it,If they can't,It will need to be flashed since the bios password is not stored like it used to be.
May 12, 2009 | IBM ThinkCentre A50 PC Desktop
Lost password for Laptop
the cmos only works for the bios passwords. The only way is to have a authorized technician reset it because its stored on your harddrive
Feb 10, 2009 | Dell Latitude D600 Notebook
How to reset power-on password.
The only way is to clear the cmos settings. However, there is a special way to do it. First you have to take out the battery and the power adaptor from the laptop. Then you need to open the laptop and look on the main board for the cmos battery. Take it out for a few minutes, maybe 5 - 10 minutes. Then plug in the power adaptor without the cmos battery nor the laptop battery and boot the computer. It will ask you to hit F1 to either load default values or to save settings. Do that. Then shut down the computer. Make sure settings is saved though. Put in back the cmos battery and the laptop battery. When you reboot, it should boot up with no password.
May 02, 2007 | HP Compaq Business NX9110 Notebook
Computers & Internet Logo
4,365 people viewed this question
David Payne
David Payne
