Question about JVC KD-G200 CD Player
I set radio stations and when I shut the car off, I lose my presets.
  • 31 Answers
The yellow wire in the wiring harness of your head unit must be connected to a constant power source, a live terminal in the fuse block that is connected to the battery and not affected by the ignition switch. If you do not have your manual this may help: http://resources.jvc.com/Resources/00/00/95/GET0182-002A.pdf
Posted on Mar 22, 2011
freetek
  • 5568 Answers
SOURCE: jvc car cd/radio
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Posted on Aug 25, 2008
  • 14 Answers
SOURCE: Radio Station Presets wont hold
hi girlygirl 1
the problem is your ignition and your permanant battery live wires are the wrong way round all you have to do is remove the stereo and you will usually see a red wire plug into another red wire and a yellow wire into another yellow wire all you have to do is change the red to the yellow and the yellow to the red and it will hold the memories fine hope that helps !
Posted on Nov 19, 2008
  • 1126 Answers
SOURCE: Just installed aftermarket stereo in 1995 Ford
The memory (unswitched) wire, usually yellow, is not connected to a "hot all the time" connector...or its fuse has opened.
Posted on Jan 07, 2010
  • 733 Answers
SOURCE: how to set time and preset radio stations on
Here you go.
http://www.pioneerelectronics.com/StaticFiles/PUSA/Files/DEHP4000UBOperationManual1019.pdf
Posted on Feb 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: Storing/presetting radio stations
For finding Radio user manuals - it is best to exhaust the manufacturer's resources before downloading a file from a potentially harmful site. Click the following to navigate directly to their SUPPORT page to look up the model number of the radio you are looking for. Pioneer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
How to I delete an occupied preset and enter another channel
My experience has always been to replace the current station preset with the new.
I recall two process:
  1. The first locate the new station that you want and tune the radio to the station. Press and hold the specific preset for several seconds to replace the old station with the new.
  2. Tune the radio to the new station and press the set button if so equipped and than press the preset button. In some radios they have group 1 and group 2. In that case press the set button once for set 1 and press it twice for set 2 and then press the preset button.
Hope this has helped?
Jan 12, 2016 | Cars & Trucks
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
Jbl radio A56840 loses station presets and no volume
Toyota vehicles have a fuse in the kick for the amp and sometimes there is located under the hood ... This is the switch turn on for the amp ... And 1 of the fuses is most likely the memory or constant power. B sure to check all fuses ... I do not have AllData pulled up . If the fuses are all good the amp or radio may be bad ... Or both ... Be sure to check all the fuses ... Many times I get clients that say allthe fuses are good and it is still the first thing I check ..Usually is a fuse ..Good Luck
Jan 27, 2014 | JBL Car Audio & Video
Can't set the radio stations
When you find a frequency that you
want to store in memory, press one of pre-
set tuning buttons 1through 6 and hold until the
preset number stops flashing.
The number you have pressed will flash in the
preset number indicator and then remain lit.
The selected radio station frequency has been
stored in memory.
The next time you press the same preset tun-
ing button the radio station frequency is re-
called from memory.
May 29, 2010 | Pioneer DEH-2800MP CD Player
Does not stay set.
your deck has two power sources a main for when your car is turned on so the radio kicks on and a remote which is always on keeping stations and clock powered passively so whoever installed it did it improperly or do to road wear and tear it was jossled lose and can simply tightened after pulling the deck out
Mar 29, 2010 | Sony MEX-BT2500 CD Player
How do I set the clock and preset radio stations on a Pioneer fhp800bt Premier?
Usually, you need to have key on and radio off. press and hold function button till u see settings menu. Set radio stations by press and hold preset # while on station till beep or display blinks.
May 07, 2009 | Car Audio & Video
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Set Radio Station Presets
Try just holding the button of choice down. In my Audi, when I had a factory head unit, to set for example, preset 2, I'd just tune to the station I wanted to program, and then hold down the number 2 preset button until the display stopped blinking. It was then preset.
Oct 09, 2008 | 2001 BMW Z3
Jvc car cd/radio
Aug 25, 2008 | JVC AM FM CD DET FACE CAR STEREO
Setting preset stations
Hi Gil, not sure what you mean by RE-setting presets but I assume your using a dock of some kind, and in that case you simply tune to the station you desire then hold down the preset number you'd like to set it to. It will overwrite the previous setting. hope that helps.
Feb 22, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
JVC KD-G200 CD Player Logo
127 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
