MY MACHINE STOPPED FROM DOING A LOAD OF LAUNDRY, THE MACHINE WAS DONE WITH NO LIGHTS ON. I HAD TO FORCE THE DOOR OPEN AND I THINK I BROKE THE CLOSING AND OPENING SWITCH. NEED TO KNOW HOW TO REPAIR. ALSO WHEN THE MACHINE COMPLETED ITS CYCLE SOMETHING CAUSED THE DOOR TO REMAIN LOCKED NEED TO KNOW WHAT WOULD CAUSE THIS AND HOW TO REPAIR THANK YOU GEORGE MY MACHINE IS A GHW9100LW
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
You will need to order a new door latch assembly. It likely did not unlock due to water remaining in the tub. Remove bottom panel to check pump filter for obstructions. Door latch is accessed by removing the front part of the rubber door boot. There is a small spring at the bottom of it that keeps the clamp tight around it. Remov ethe outer clamp and fold the RH side back to expose the door latch assembly. You can download the service manual at teh link below if you would like.
Service Manual
Kelly
Posted on Mar 22, 2011
What does the error code UL mean?
UL means UnLevel. To fix , open door of washer, and redistribute the clothing/laundry in the machine, and press start. It should start spinning again. Sometimes , if you have a overly heavy load of laundry above will not work. What I have done is, put my weight on the machine (upper body laying on the top) until the machine has extracted enough water so the machine will be balanced.
Dec 10, 2015 | Washing Machines
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Door stuck closed after wash is done
If the water in the machine is above a certain level a fail safe on the door lock will not allow it to be opened. Check the filter, make sure the machine has completely drained. Obviously, there may be a problem with the lock itself but try this first.
All the best
Mar 20, 2013 | Bosch Axxis WFL 2060 Front Load Washer
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Once the wash cycle begins, the washer door is locked and cannot open until complete cycle is done. Is this normal or is there a way to stop wash cycle and open the door?
If this is a front load washer, yes it's normal.
You wouldn't want your laundry and all the water falling out on the floor because the door didn't lock, would you ?
Jan 17, 2011 | Washing Machines
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
WATER IS COLLECTING AND STAYING IN THE GASGET AND HAS AN ODOR, HELP, Please
Betty, this is problematic of all front loading washers. I have some helpful suggestions, which have helped us with our own front loading washer.
First, whenever you're done doing a load of laundry, don't close the door all the way shut. Leave it open a couple of inches for a day to let it air dry out, which will prevent the nasty smelling odor you're getting.
I also take a small rag/washcloth to wipe out the door seal/gasket after we're done washing, that way, there's less water to contribute to foul odors, etc.
The other thing we discovered is to make our last load of wash the hot water wash, whenever we're doing whites, or the stain cycle. This helps get rid of any gunk that might hang around between wash days.
Now we don't always have a hot water wash everytime we do laundry, but by just wiping out the gasket and leaving the door open, we eliminated the odor issues completely.
Frankly, the gasket shouldn't have to be wiped out when you're done washing, but that's a design issue that we've overcome with a simple washcloth. So just do these simple steps and you'll save yourself some frustration.
We really like how clean our laundry gets with the front load washer and how little water is needed to do a load, so we've decided it's worth taking the time to wipe the gasket once we're done for the day, and to leave the door open to prevent any nasty odors.
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Electrolux front loading washer - door is locked, won't unlock
I have an Electrolux front loading washer. I just got done washing a load of laundry and the door will not unlock. I tried washing it for a second time thinking maybe it would open again. No luck.
Nov 09, 2008 | Washing Machines
I need help
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
Aug 26, 2007 | LG WM2077CW Laundry XL Front Load...
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
