Question about Black & Decker 18V Cordless Drill/Driver
Not charging. led light is off - Black & Decker 18V Cordless Drill/Driver
    New Friend:
  • 49 Answers
Perhaps your charger is stuck somewhere and that's the main reason behind it that it's not working properly. So, I want to tell you that you need bring new charger now.
Posted on Jul 06, 2013
My charger is not working
Posted on Dec 26, 2011
Ideas Arlec PS906 mobility chair charger. It's saying that battery's charged, only on with one red light when charger off, all lights on when charger attached. It turns on but lowest of power, Elaine
Hi again I'm a bit confused a PsS906 arlec charger is a 12 volt charger ??? Can u supply more information .cheers Hi when u turn charger on red ( led ) should come on / when connected to battery / red & yellow ,( led ) should b on /it's in charging mode /when green ,,( led ) turns on battery is charged.cheers
Dec 09, 2017 | Health & Beauty
Charging light shows green--manual says charged when light goes off-_I would expect a red light when charging--Is it charged when green light shows???LUMIX ZS8
Hi if u r using DE-A60 or DE-A60A CHARGER / when charging green LED is on when fully charged LED Turns off ...cheers
Nov 01, 2017 | Health & Beauty
Harley charging LED indicator does not light
light off means it is charging I would say , light on means n charge.
Mar 12, 2014 | Harley Davidson Motorcycles
When charging my light stays red does that mean its charging
Some chargers have 2 LEDs (lights), some have one. Both chargers have an LED that is red (or orange) when the charger is charging a battery and turns green when the battery is charged and the charger has dropped back to trickle charge mode or off.
On the charger with two LEDs , the extra LED is normally red to indicate the mains power is connected.
Sep 10, 2013 | Razor MX500 Dirt Rocket
Just want to know how to tell if a Dell Latitude C610 battery is dead
With dell laptops, there should be buttons near the led lights.
Check the battery charge by pressing the status button or image on the battery near the LED's.
Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press the button, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flash, or blink, there could be a problem with the battery.
Hope this helps...
Sep 13, 2011 | Computers & Internet
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
We Dont Kno!!!
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop power it up then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 02, 2009 | Dell Inspiron 6400 Notebook
My duracell crank light 3 in 1 is not working properly. I rotated crank handle for about a minute or 2 long,thinking that charging would be enough and led torch will light for few minutes during power cut...
I found with my Duracell crank lights they periodically need a good charge to function well. On the side there is a 5v charger socket - suggest and 8-10 hr charge. There is also a USB with a switch between IN and OUT. With a suitable USB cable in the IN position, the light can be connected to a computer to recharge. Hope this helps.
Jun 27, 2009 | Duracell Crank Light 3 In 1, 3 Led...
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Jan 27, 2009 | Dell Latitude D600 Notebook
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Black & Decker 18V Cordless Drill/Driver Logo
328 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Marvin
Marvin
Robert Monigold
Robert Monigold
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
