Question about Dynasty DGRSC 36-6 Gas Kitchen Range
I purchased my home last year and the previous owner didn't leave a manual. I also hear a loud banging sound when the oven heats up and cools down. I need to know the best approach to clean the oven.
    Scholar:
  • 143 Answers
Your stove is going from room temp soy 65 to 70 degrees up three hundred in a couple of minutes that chance in temp shocks the inside and the metal expands and contracts and that should be the bang you hear my gas stove does the same thing it should have a cleaning cycle it gets so hot inside that it melts away or burns everything but you should be able to get cleaner a walmart or home depot or even lowes you should be able to download manuals on line and that will save you from printing a thousand pages
Posted on Mar 22, 2011
What causes a loud bang from oven?
If you hear a loud bang the SECOND time you try to light an oven, it means you've just had a small explosion when the gas from the FIRST try ignited outside the heating tube. I would have a professional check your oven before using it again.
Jul 18, 2014 | GE Spectra JGBP35 Gas Kitchen Range
Oven cuts out with a bang when i turn it on ???
if you hear a big bang, and it wont light right away, it is normaly the ignitor thats going bad in oven. the ignitor has to get very hot to ignite the gas. orange in color. if this is the problem be very carefull not to bump the new ignitor on any thing, if you replace it yourself.I had the same problem last year,when trying to light oven it blew the door part way open because the ignitor was bad and the build up of gas caused this.
Feb 01, 2012 | Fagor Ovens
Our wall oven will broil, but will not heat up to bake. Also the fan to cool down is super loud, where do I start? It' a GE model-JGRP18GEL5BG
IT SOUNDS LIKE THE HEATING ELEMENT HAS BURNT OUT AND THIS IS WHY YOUR OVEN DOSENT HEAT UP, I WOULD ALSO SUGGEST THE REASON YOUR FAN IS LOUD IS IT MAY BE OFF BALLANCE AND LOOSE AND AS ITS TURING IT BANGS ON THE FRAME , SO REPLACE THE ELEMENT AND FIX THE FAN .
Nov 09, 2009 | Ovens
I cannot find the model number for my maytag oven to download a manual. I've lived in my home for three years, the oven was there when I got there so I don't know much about it. Now the display is saying...
Unfortunately, there is no standardized location for the model # sticker. Look in all for side corners of the oven door, then look on all four sides of the oven opening.  Look on the inside of the oven for the name plate.  Look under the stove top where the burners are and finally look behind the oven.
As a last resort you can look on your sales contract to see if you can contact the previous owner for advice.
Oct 25, 2009 | Maytag MEW5530D Electric Single Oven
Microwave won't heat
Sorry my Clarification Request came out as a single blob of a paragraph.
That's not how I typed it. I never write that way!
So I've pasted it here, but as a solution.
Magnetrons generally should last about 2000 hours, but several factors can shorten that.
If it's not OVER ten years old (from the purchase date or the date on the tag inside the unit) then the magnetron is still under warranty.
From the owner's manual:
"For the second through the tenth year from the date of original purchase
"The magnetron tube, if the magnetron tube fails due to a defect in materials or workmanship. During this nine-year limited warranty, you will be responsible for any labor or in-home service costs.
"For the above limited warranty: To avoid any trip charges, you must take the microwave oven to a
General Electric Customer Care® servicer and pick it up following service. In-home service is also
available, but you must pay for the service technician’s travel costs to your home."
GE Customer Service is here, and you can verify the warranty status and find your nearest authorized servicer.
If you're sure the magnetron's bad, it's still under warranty, and you or a friend are handy, they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
It does sound like the magnetron overheated and the magnetron's thermostat opened until it cooled down.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
Since yours is a counter top model, there are less of those factors to worry about.
When you hit Start to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
You can find helpful exploded view diagrams and order parts if needed by entering your full model number from the tag on the oven here.
Let us know what you find out or decide.
Jul 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud noises, bangs and sounds like water falling
if it’s a banging sound--- I know one of the noises the system 2000 will make is a bang or rattle at the end of the run cycle, which we call "shudder stop". If this is your noise then I have to give you some bad news here. Sorry....... The only way of repairing this is by having your compressor replaced as it has to do with an internal problem in the compressor itself. There may be a silver lining, though, if you are the original purchaser and you have the receipt. Some of these systems came with a 10 year warranty on the compressor, so you might want to check this out.good luck
Dec 10, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Dynasty DGRSC 36-6 Gas Kitchen Range Logo
121 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
