Question about RCA HD61LPW42 61" Rear Projection HDTV
My HD61LPW42 makes a high pitched wirring noise after it is on a few seconds sounds like the fan is rubbing against something but doesn't appear to be. The picture quality is still good and the tv continues to play just a very loud high pitched sound.
    Genius:
  • 1,030 Answers
This might be a noisy color wheel . this is a motorized wheel that produces the color in the set. it could be something else because of your statement of picture is ok. if it the color wheel the set will eventally shut down. this part used to be avalible and fairly easy to replace. it has got harder to locate. The other possibilites includes a small leaky capacitor in the powers supply but that is more like a whine. a tech would have to take the back off and locate the noise.. i believe this unit might have 2 fans and a color wheel. three moving motors.. anything that moves eventally dosnt
Posted on Mar 22, 2011
Why is my Haier washer making a loud high pitched noise?
No. The high pitched noise did not originate in the control panel but rather in a part of the machine that was chafing or rubbing against something. And now the mechanism is stuck. Check for that first before messing with a control panel.
Sep 16, 2016 | Haier Washing Machines
Recently had fan replaced, now it is doing the same thing in heat and air cycles. when time for fan to come on to send air into the house it makes and aweful noise again and doesn't come on. Any...
Visually inspect the fan and the inside of the fan housing. It sounds like it's rubbing against something or is loose and therefore rubbing against something. May be as simple as adjusting and tightening a bolt or removing something that got into the fan housing.
Oct 27, 2013 | Coleman Heating & Cooling
Our refrigerator is making a high pitched ringing/buzzing sound. Any way to fix this? Thanks!
You need to pull the refrig. out from the wall and determine the source of the noise. It maybe comming from the "condensor fan" usually located at the bottom rear. The blade maybe rubbing against something. Eg. paper or shield around the fan. It is also possible that the noise is comming from the inside. In this case, it could be the "evaporator fan" rubbing against something. Good luck ...Jerry
Mar 04, 2013 | Refrigerators
WHEN I TRUN OFF THE TV IT MAKES A NOISE LIKE SOMETHING IS TURNING AND RUBBING SOUND.
2 solutions for problem. ONE color wheel is grinding. IF high pitched sound is heard. Second bad fan or fan contaminated with dust. Turn TV off unplug. LET cool down ... Using canned air clean all vents on rear of set. MAY also need to remove cover and find the 3 fans inside of set.
Feb 16, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a rooftop unit 10tons when i turn the fan on it makes a rubbing sound i remover the fan and the motor the motor make no noise I changed the berrings in the fan but it still makes the loud rubbing...
the unit may settled and it is rubbing against something it may be the cover...run the unit on low and see then to high that may lead you to the location good luck
Sep 08, 2009 | Heating & Cooling
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung HLN5065W, SVC#HLN5056WX/XAA - Made 12/2003
check the color wheel in front of the lamp
May 25, 2008 | LG 42LC7D-UB Television
RCA HD61LPW42 61" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
