I have an Oreck quartz heater that doesn't seem to cycle via the thermostat. I would like to find an owners manual to assure i'm setting it properly
    Brigadier General:
  • 4,736 Answers
If what you have is an Oreck, Heat Wise Infrared Heater, here's a link to the owners Manual that you can download and print.
http://www.oreck.com/PUG/21085-01%20REV%20A%20Heatiwse%20%28sm%20manual%29.pdf
Hope this what you are looking for.
Posted on Mar 22, 2011
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
Heater runs 1 cycle then turns off
Replaced 301 80C 16A thermostat, purchased on ebay for $6.00, fixed problem. to Fix standing at front, Remove left side panel, two small screws hold thermostat in place. LifeSmart wants $36.00 for same part. Fixed problem.
Oct 18, 2013 | Lifesmart Renew Infrared Quartz Heater...
The cooling coil in the back of the freezer frosts up and needs to be manually defrosted nearly ever 2 weeks. The timer seems to cycle properly and the compressor cycles properly but the defrost cycle...
The ohms of the defrost heaters vary, but all you really need to do is check it for continuity. If its open, its bad. The defrost thermostat must be closed for defrost to happen,it is in series with the heater the defrost thermostat opens to terminate defrost, then the timer puts the unit back in run mode.
To check the defrost thermostat you have to put in in a freezer for a while then check for continuity . The actual open and close temps are usually stamped right on the defrost thermostat Its considered good practice to replace both the heater and the defrost thermostat while you are in there
Jun 28, 2011 | Refrigerators
Proper settings for the Honeywell thermostat T87K
I'm going to answer your questions based on the way I THINK your system is setup.
If anything isn't making sense, please feel free to ask.
2> cycles per hour is for air handling only, if there isn't a call for heat, you may still want to move air in order to not have the space feel "stuffy", or develop a moisture issue.
3> the cycles per hour to choose depends on alot of variables. Some of these include geographical location, type of construction, use of the structure (what is this building used for?)
4>The high and low limits are for the target fluid temperatures for the boiler. The cycles per hour are for the air handler.
Your installer should have setup these things for you, and been able to explain them to you in a reasonable manner.
Hope this helps! Feel free to ask any more questions you need.
Helping Hands Services
_ Fairbanks, Alaska _
Feb 11, 2010 | Heating & Cooling
Cycles on and off after reaching desired temperature
The problem sounds like the thermostat which is probably a bimetal strip. It sounds like the bimetal strip is just constantly bending one direction then the other. It could be possibly adjusted by bending it -- this would be a trial and error process.
Or, it could be replaced.
Apr 29, 2009 | Lakewood LAKQTV22 Utility Heater
Loud buzzing after heating up
the buzzing is normal.  there is an element inside the quartz tube much like a filament in a light bulb.  as this heats up it starts to move.  where you have electrical energy you also have magnetism produced. metal objects vibrate when they are in or within a magnetic field. the element is tungsten wire and vibrates off this magnetic field.
Oct 13, 2007 | Marvin Quartz Radiant Heater
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
