Question about Acer Aspire 5500 5570-2609 Laptop
No power Thanks, I checked the power cable. Light is green, but laptop has no power.
  • mphamm Aug 03, 2008
    Do you think I could have worn my battery out by leaving my laptop plugged in all of the time?
    Scholar:
  • 39 Answers
If you have no power on your computer I would recommend you unplug the Battery and try to power it on using the AC ADAPTER only. This will tell you if your battery was an issue or not. Secondly I would recommend highly to RESEAT meaning remove the memory and place it back in the computer but when doing this make sure you remove the battery and unplug the computer first. This might help you with the power and if you still have no power get an universal Adapter like from best buy and try it with the corresponding TIp for your computer and try to power it on that way . If you still after that get no power unfortunately it could be the jack where you plug the ac adapter that could have become loose inside or the motherboard is shot which part and labor cost would probably exceeded the cost of unit. Hope my answer gets you closer to a solution.
Posted on Aug 11, 2008
Dear Experts , I have a power problem with my DELL PP01L laptop ,it was very well operating and suddenly it goes off ,i tried to repower it on again but in vain ,Could it be a battery problem ? but i...
It should work even without the battery when the power adapter is connected. Try to check if there is a green light on the adapter itself. Also check the cable of the adapter and the contact point at the end of the cable that goes to your laptop as well as the port on your laptop. Check if they are broken. To test, borrow the same model of adapter that works.
Oct 12, 2010 | Dell Latitude C640 Notebook
Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Jul 06, 2010 | Motion Computing C5 Tablet PC
Will not power up. Green light on power source
Please do a power drain. To do so:
Turn Off the laptop, uplug battery, unplug power cable and any external device. Keepon holding the Power button for 10 secs. Plug all the devices & battrey. Turn On the computer. It should take care of the issue.
Mar 23, 2010 | Acer Aspire 9500 Notebook
Wont start
Hi there, please explain what's you face. Also you can follow the steps.
1. plug on the the power cable. Is there green light are on in adepter? Is not then your power cable damaged.
2. if you r battery fully charged then turn on your laptop with out connecting power cable. If your laptop booting then system is perfect.
3. Try to plug on by a different Acer laptop users power cable. and see what's going. I need these information for further instruction. You just say "wont start" i don't want to give you any blind suggestion. so please let me know more about it.
Thanks.
Feb 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Failure to power up
Check the cable and do power on self test(POST)
Aug 25, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Dell latitude d600 will not turn on / power on
it means not charging the battery pack, did you check the dc jack connector, or the.
charger check it if working properly, if the same problem open the laptop then check the baord
thanks
Jul 12, 2009 | Dell Latitude D600 Notebook
There is no power going into my laptop with or without power cord. It has a battery in it and the power cable seems like it is getting power, because the green light is on on the box.
check your DC output voltage using multimeter. if you dont have a multimeter short circuit your power pin using a wire or paper clip. if that green light goes off your charging unite is working properly.
Jan 22, 2009 | Sony VAIO VGN-FS660/W Notebook
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
Wireless key on my laptop it wnt work
Check all cable connections
Ensure devices are powered on
Check the cable connection or to the hub ensure you have green link light
Make sure you are using the proper cables - CAT5e ? CAT6 - not crossover
Jun 09, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
