Question about Stinger 1 Farad Chrome Cap Capacitor W/ Display + Neon
It stays on all of the time and it is draining my battery
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Stinger Master
  • 2,226 Answers
Once a capacitor is charged, it should not be draining the battery, are you sure it is not something else in the system?
Posted on Mar 22, 2011
How is 2001 Mustang GT parasitic draw on battery related somehow to FU 27 and FU39? Battery drains overnight but I cannot narrow down a faulty component.
Allfordmustangs.com has an article if you Web search your car with fuse 27 and 32 as part of the search. It blames the GEM as part of the problem(wiper) and also points out that the radio has several power feeds. Fuse 27 is hot all the time, but fuse 32 is only hot in ACC or Run. So as long as you can test fuse 32 to be hot in only Acc or Run, it should not drain the battery in Off position. You might want to test the ignition switch to verify it is really turned off.
The all mustangs article had different symptoms, as you did not indicate whether the fuses popped.
The wiper motor is suppose to derail and turn off. If you can unplug the wiper motor overnight and the battery stays up, you would know that it is either the wiper motor or wiper control. The radio is on the other fuse circuit. But whether the radio can drain a battery in a short time, you need to measure draw, but if the fuse pops, the battery should stay up. Again, disconnecting a circuit like a radio, and then having the battery stay up, would point to the radio circuit being at fault.
Oct 14, 2014 | 2001 Ford Mustang GT
Why is my clock and radio staying on after I remove the key in my jeep Liberty 2007
Modules or Relays are not going to sleep
or timing out & running the battery down
Have to leave the doors closed up to 1/2 hour with a
an amp meter on the battery & pull one fuse at a time
to isolate the circuit
You Tube has video on (Parasitic Current Drain Test)
Aug 12, 2014 | 2007 Jeep Liberty Limited
Battery drain overnight
Usually if battery is good. Its usually a parasitic drain. You can use a standard multimeter, and put across each fuse top. Two little tips. If you see a voltage even a little bit. That's a drain. Find what fuse go's too. And diagnose.
Jan 15, 2014 | Dodge Intrepid Cars & Trucks
Radio stay on after Jeep is turned off
The remedy consists of finding out the real cause of rapid battery discharge. It isn't the clock. Could be a failing starter.
Dec 24, 2013 | Jeep Cars & Trucks
Removing power to onstar
The amount of Drain from On-Star is Extremely Minimal, You probably have another drain that is causing your drain. I would Troubleshoot that drain. A drain of 50mA is acceptable
Apr 04, 2013 | 2000 Cadillac Escalade
I have a current drain which kills my battery if my 2003 vTundra is not used for a week. We know that if we dissconnect the wire to the fuse box the drain stops. We have pulled all the fuses one at a time,...
all vehicles since the 80s have a continuous drain, it keeps the ecm , radio keyless etc, anything that requires memory, although one week is a little short, i would wonder if the battery is not getting a full charge?? like only used on short trips. disconnect the neg terminal and bridge it with a test light, it should glow bright for a few seconds then dim, that is normal , if it stays bright pull fuses one at a time , you should find the circuit that is staying closed
Nov 11, 2010 | 2003 Toyota Tundra
Toyota Tercel door sensor stays on constantly and drains battery
find a way to get to the switch in the rear hatch and try diconnecting the switch.
Jun 06, 2009 | 1992 Toyota Land Cruiser
Secuity system light stays red and drains battery
Switch toggle switch with ignition ON , Sounds like it it is on the VALET mode
Mar 26, 2009 | Nissan Vehicle Parts & Accessories
Stinger 1 Farad Chrome Cap Capacitor W/ Display + Neon Logo
163 people viewed this question
Top Stinger Car Audio & Video Experts
xxxxxx xxx
Are you a Stinger Car Audio and Video Expert? Answer questions, earn points and help others
