Question about Car Audio & Video
This morning I was having a problem getting into my bmw, apparently because the battery was totally dead. Road service got into the vehicle and tripped the lock and now there are 2 codes I need. One is for a radio and an immobilization device. What can I do? It's for a 1989 bmw 750il.
  • Car Audio & ... Master
  • 4,944 Answers
BMW codes for the older BMW can be difficult to decode
Try asking here and they will be able to offer free advice (Mention this FixYa Forum)
CLICK HERE
Posted on Mar 22, 2011
Vehicle acts like dead battery but it is not.
It is a type of security system. Like you said all functions are turned off until you push button because battery is disconnected from system.
Apr 28, 2016 | Cars & Trucks
Tip
Door lock cause of dead battery
A dead battery, one recent cold morning, found me at the service shop. Tests indicated the system was charging properly with no battery drain. I asked if the test were done with the doors locked. They were not. A second test (car locked), revealed a misaligned trunk lock switch. Switch repaired, battery charged, problem solved.
on May 19, 2008 | 2006 BMW 650CIC
93 bmw 740 does not start usually mornings after it starts first time it will start the rest of day but the following morning it wont start again i think its not getting spark now today it did not start...
I would start by cleaning battery cables top and ESPECIALLY bottoms. I know a pain, but the lower ends are exposed to road grime & grease. Also have your battery "load tested". Between all the electrics and the required voltage to run ignition, they can be a pretty big load on battery. (I have 93 M5 and it has same issues when I store it over the winter months)
Apr 04, 2011 | 1993 BMW 7 Series
2006 BMW X5. got oil service yesterday and new battery. Drove all morning today and then on the motorway, battery light comes on with fuel injection message and car loses all power. after 3 attempts it...
was this problem there before replacing battery? if not a loose connection at battery or in battery compartment the code is a temporary code and when connection severs the code is cleared check the time after starting till problem occures and see if there is a pattern to how long it takes
Jan 13, 2011 | 2006 BMW 5 Series
I have a 2000 BMW X5 - 4.4 - The battery light came on and the engine derate power then shuts down. The road assistance tecnician jumped start but big sparks coming out to the firewall post.The battery was...
If you got a spark from the fire wall I think the is where the - side of your bat. is bolted to for a ground. Make sure the ground is tight also make sure the batter cables on the batter do not turn when you grab thim if they do tighten thim up.Take the vehicle to Autozone ask thim to test the battery it is possible you have a dead cell...if not it is most likely the altanator, they can test it also but it has to be removed from your vehicle unlike the battery.
I hope this is of some help, good luck
Dec 02, 2010 | 2005 BMW X5
My lexus E350 battery goes dead if car is not used for a week. Had the battery checked with dealer says it is OK
This has happened to me TWICE in the past 4 months. I had Lexus road side service come out both times to check the car out. Each time the battery was totally dead. The road side mechanic said that if the car is not driven at least 15 minutes nonstop a day, the battery runs dead as there are so many draws from the car on the battery. If you do alot of stop and start driving like I do, that isn't enough to recharge the cell of the battery, it must be non stop driving time. Recommend that I get a 1.5 tricky charge device an hook to battery at least one night a week to keep the battery charged. This is really frustrating with such a new car. I've spoken to other owners of other model luxury cars and no one has had this problem.
Sep 13, 2010 | 2007 Lexus ES 350
My battery is running dead every two days! I jump it and starts up, after several minutes with the jumper pack cables! This has happened 4 to 5 times since I purchased the vehicle just 2 weeks ago...Am I...
If the key is in off position it won't drain battery.
You may have battery draw in that vehicle , or the battery itself is going out.(BMW batteries are good for 4-5 years)
Both cases needs to be checked by workshop , cause BMW very sensetive to the voltage drop. When you disconnect battery you may need to perform some settings adaptation after you replace it or connect it back.
New BMW requared to reset computer even after brake job and battery replacement.
Jun 15, 2010 | 2006 BMW 750Li
1992 pontiac grand am totally dead,
yes it is the battery,was it a little cold out this mornin??? cold weather usually exsposes the bad batteries in vehicles,and sometimes there is no warning but your battery is old and should be replaced,hope this helps
Sep 09, 2009 | 1996 Pontiac Grand Am
Battery going dead 2001 BMW 330i
i have seen on more than one occasion the new ALT going bad after about a week or so you may want to check your charging system again and see if you can warr out the alt if it is bad
Nov 16, 2008 | 2001 BMW 330
Service Engine Light on and die on the road for a while
Try going to your local auto parts store and have them check the computer. Doing so should tell you why your vehicle is not running right. Also it might be a bad Mass Air Flow Sensor that the dealer put on your car.
Aug 06, 2008 | 2003 Buick Regal
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
