Question about Electrolux Dryers
Electrolux dryer, purchased less than a year ago, will not run. Breaker is fine, have unplugged and plugged in, no results.
  • Electrolux Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 22, 2011
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Have a Electrolux dryer and the moisture bar pulled loose by bib overalls and have the new one but am not sure which wire terminal goes where. 2 wires and the dryer used to dry on one normal cycle but
Hello lester haugstad, thank you for your post!
I understand that the moisture bar inside of your Electrolux dryer was pulled loose and you would like to reattach it. I have researched and there is not an available part guide to show how the moisture bar is reattached. I would recommend seeking assistance from a professional for proper installment of the part. I hope this information has been helpful. -Matt
Oct 16, 2014 | Electrolux Dryers
Countdown timer not working
Good Afternoon Friend,
I understand that the timer on your Electrolux dryer, model#EIMED55IIW, is not advancing to show you how much time is left on the dry cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Restore power and restart your dryer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
WP
May 18, 2014 | Electrolux EIMED55IIW 8-0 cu- ft- Electric...
Electrolux cde7700lw0 dryer
Good Afternoon Brain, this is Z. I am happy to assist you!
I understand that your Electrolux dryer (CDE7700LW0) door indicates it is open and your dryer will not operate. Let's try resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your dryer. Select a normal cycle and verify if the dryer will start. If your appliance will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your appliance.
Apr 10, 2014 | Electrolux EIED55I Dryer
Electrolux dryer EIED55HIWO
Hello - Typically 88:88 on an Electrolux dryer indicates a generic power failure code. Try resetting the unit by unplugging it or flipping the household breaker off. Wait approximately ten minutes.
Dec 10, 2012 | Electrolux Dryers
I HAVE A ELECTROLUX T3650 TUMBLE DRYER SHOWING E 08 FAULT
Hi - Typically error code E08 on Electrolux models indicates that it is recommended for a professional to check the mist value on the motor. Try resetting the unit by unplugging it or flipping the breaker to the household circuit breaker. Wait approximately ten minutes and turn on the dryer. If the error code does not clear and it is ineffective, contact a professional to move forward accurately.
Oct 12, 2012 | Electrolux Dryers
Electrolux front loading washer
This could be the result of anything. I would call an appliance tech. It will save you time from trying to troubleshoot on here.
May 15, 2012 | Electrolux Washing Machines
Hello: I have a Maytag MDE9700AYM that was purchased three years ago but has been installed for less than one year. After the unit runs for 10-20 minutes, the circuit breakers trips off. Otherwise the...
It's possibly the circuit breaker rather than the dryer itself. Usually when it trips, it is overloaded or shorted. Overload can be a result of a loose connection or a bad heating element,when you remove the old breaker, see if it has some noticeable burn/corrosion marks where the wire is screwed down, I think replacing the breaker will fix the problem. Hope this helped Tim
Nov 07, 2010 | Maytag MDE9700AYM Electric Dryer
I was drying, a load finished fine. Put the next load in, turned the knob for setting and I got the error code of "PR" and it wont turn on. The display is not working. So I unplugged it, then reset the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 30, 2010 | Electrolux Frigidaire Affinity AGQ8700FE...
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
137 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
