Question about Haier HTE14WAA Top Freezer Refrigerator
Haier refrigerator does not cycle off. - Haier HTE14WAA Top Freezer Refrigerator
  • 132 Answers
There is always more than one reason why a refrigerator will not cycle off.
To diagnose the problem it is best to use a flow chart which will guide you through the issues to look for.
Try obtaining a service manual from Haier, this will contain a diagnostic chart for you to follow.
Posted on Mar 22, 2011
  • Prem Mulberry Apr 13, 2011
    A good source for Haier refrigerator service manuals is here: http://steprightupmanuals.com/washing-ma...
I have a Haier refrigerator model #rrtg18paaw and the freezer is not working but the fan is please help?
At this point I am assuming the refrigerator portion is working. It sounds like it may be a thermostat or a low refrigerant charge. If you cannot find it with the links I have attached you should contact a servace tec but also it possibly is in warrenty so start where you purchased the unit.
Haier10 11 cu ft Top Freezer Refrigerator White
20 7 Cu Ft Frost Free Top Freezer Refrigerator ENERGY STAR HT21TS45SW
Haier Refrigerator Parts
Haier Refrigerator Model RRTG18PAAW Parts
May 30, 2016 | Haier Refrigerators
Still running cold when off
The thermostats are junk, the stick on or cycle off too soon on some, cheap chinese junk refrigerator.
Jul 13, 2012 | Haier HSB03 Compact Refrigerator
Haier prcs25tdas refrigerator has frost on back wall of freezer compartment
Remove the panel. Check the heater and bimetal thermostat for continuity. If either is open then easy fix. Note: thermostat only has continuity if cold. When it gets over 50f it opens to kill power to the heater during the 20 minute defrost cycle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 17, 2012 | Samsung RS2556 Side by Side Refrigerator
Haier Mini spilt HSU18VC7 compressor runs for 5 minutes then stop 3 minutes then run another 5 minutes and so on.
This is called short cycling. It sounds like the compressor is getting hot and opening a bi-metal overload, which shuts the compressor off. The compressor cools, because it is not running and the bi-metal contacts close allowing the compressor to start again. This will repeat itself and is usually due to low refrigerant, which usually means there is a leak in the normally sealed refrigerant lines. The refrigerant cools the compressor windings and if it is low it cannot do that, hence the shutting off of teh compressor, cooling down process and restarting of your compressor. Short cycling will ultimately ruin the compressor.
If this has helped you please give me a rating worthy of my diagnosis.
Aug 03, 2011 | Haier Heating & Cooling
Hi, can u answer me who mad haiere refrigerator?
Haier is actually the name of the company.
The central Haier building is in Qindao, PR China. Haier has headquater is in New York, USA, and an industrial park i Camden, USA. The CEO is Mr Zhang Ruinin. It is safe to say , based on that information, that Haier refrigerator is made by Haier.
Mar 06, 2011 | Refrigerators
Temp. is on automatic settings for "Red Wine" but fluctuate between 51-59 degrees, not to mention makes all sorts of noise (common refrig. noises) is this normal? Haier 35 bottle wine refrigerator
temps will fluctuate. depending on door openings and defrost cycles.no abnormal noises heard on the ones ive worked on but appliances tend to be noisier then they were. if less than a year old have an authiorized servicer go out and look at.
Sep 16, 2009 | Haier Refrigerators
My freezer fan is not working. Can it be fixed?
The fan won't work when the unit is in the defrost cycle. Some won't run when the door is open. It won't run when the compressor isn't running. Test it here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php And yes, you can replace it.
Jul 11, 2009 | Haier (492420265334) Refrigerator With Ice...
Have a Haier water cooler with the fridge compartment in the bottom. Compressor on the unit just started running continuously, instead of cycling on and off. now the chilling bowl that cools the water...
removed one of the two thermostats... the one that controls the temp in the lower refrigerated compartment. Now the water cooler functions correctly but the lower refrigerator is not cold enough to keep perishable food in it, but its better than it was.
Dec 09, 2008 | Haier Refrigerators
Haier beer dispenser model HBF05E
Either its not getting cold enough to shut off or your thermostate isnt working.. thats the only thing that cycles it.
Aug 27, 2007 | Haier (HBF05EAVS) Beverage Dispenser
Haier HTE14WAA Top Freezer Refrigerator Logo
209 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
