Question about Ovens
THE LIGHT BULB BURNED OUT AND LOOKING THROUGH THE MANUAL DOESN'T TELL HOW TO REPLACE IT. IT JUST SAYS ON PAGE 5 IN A NOTE THAT RATING PLATE, OVENB VENT(S) AND OVEN LIGHT ARE LOCATED ON THE INSIDE WALLS OF THE MICROWAVE OVEN. DOESN'T SAY HOW TO GET INSIDE TO REPLACE IT. ANY HELP YOU COULD GIVE WOULD BE GREATLY APPRECIATED. MS. CHRIS FULTON
  • cffulton Mar 22, 2011
    This is a GE Microwave model JES2251. I found the light but it is covered by the solid inside except it has holes so the light will shine through. There are 2 screws on the outside of the same side as the light that I was able to take off. But there are 2 other non-screw type things holding the same side to the back. There is also a metal plate next to the light "holes" but I see no way to take it off. You must be able to change a burned out light bulb, true?
  • 643 Answers
I need to know what make/model oven you have?
Posted on Mar 22, 2011
    Genius:
  • 1,622 Answers
Using your oven light to check on food is a good idea to conserve energy. Opening the oven itself to check on your meal allows heat to escape. When the oven light suddenly doesn't work, you'll want to replace it using these simple instructions.
Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
Tips & Warnings
Consider replacing the switch on the oven door if you replace the bulb and the light still does not work. Shut the door and open a few times or press the button manually to see if the light works randomly or not at all.
Bottom oven lights keep burning out.
The oven bulb is different from an appliance bulb. The glass and base are specific for the high temperature application that is seen in a oven
The link from sears shows a sample of an oven bulb and the price represents the special characteristics.
I have seen where some bulbs are rated at 130 volts?
Range Oven Light Bulb Part Number 316538901 SAME DAY SHIP GUARANTEE from...
This link from Amazon relays some of the one star reviews of the appliance light used in the oven application. All ovens are maybe not equal where the heat may be more significant in one make over another.
Amazon com Customer Reviews GE Appliance 21188 40 Watt 415 Lumen A15 Light...
Another set of reviews that again show problems in some applications for bulb life.
40 Watt Incandescent A15 Clear Appliance Light Bulb 416768 The Home Depot
Not many reviews on this bulb. The 130 volt rating is an indicator of longer life? Of the choices I wood choose the following.
Sorry I couldn't help you more. Disappointing that no bulb stands out as the very best.
Bulbrite B40A15C 130V 40 Watt Incandescent A15 Appliance Bulb Clear Amazon...
Jan 09, 2016 | Ovens
Replace bulb
oven bulbs are special bulbs only available from an oven service agent
although the ratings are the same , the glass used is actually pyrex glass as ordinary glass will not handle the oven temperatures
Dec 24, 2017 | Viking Professional VESO130 Dual Single...
My E30EW85GPSS double wall oven lights won't turn on. Both ovens heat up but neither oven lights up. Help!
Oven lights burn out just like any other light bulb. If you remove one, you may be able to tell if it's burned out if it is rattling or discolored. They are generally an inexpensive bulb to replace.
Sep 24, 2013 | Electrolux Icon E30EW85GPS 30" Double Wall...
My Maytag MGR5750ADW oven will take forever to preheat. It does get hot, but the preheat light takes a very long time to go out. Food takes much longer to cook as the oven does not seem to get up to temp.
Hello there and welcome to fixya
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Aug 10, 2011 | Maytag Ovens
It "popped" a circuit breaker
NORMALLY THERE ARE SCREWS TO REMOVE TO ACCESS A PANEL TO REMOVE THE LIGHT BULB. IF THERE ARE NOT, THEN THE EXTERIOR COVER MAY NEED TO BE REMOVED TO ACCESS THE LIGHT BULB. THIS EXTERIOR COVER HAS SCREWS.
MAKE SURE YOUR CIRCUIT BREAKER IS OFF BEFORE YOU TRY TO REPLACE THE BULB.
Feb 20, 2011 | Ovens
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    GE Profile convection with light bulb burning out
    Multiple possibilities.
    • Being used as a night lite. (continuous use)
    • Not using a light bulb designed for use in a oven.
    • Inexpensive bulb. (very low lamp hour rating).
    • Oven door slamming.
    • Over voltage condition.
    • (My favorite) Light bulb swapping Gnomes.
    Please take the time to give this solution a fix ya rating.
    clarkco
    Feb 22, 2009 | GE Profile JTP18 Electric Single Oven
    GE Profile Convention Light Bulb Not Working after Replacement
    With a volt meter you must verify power to the door light switch and the light socket.
    You can also unplug the oven and do this with a meter set for continuity.
    Feb 17, 2009 | GE Profile JTP18 Electric Single Oven
    Jenn-air microwave light bulb
    This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and appliancepartspros.com provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
    Dec 31, 2008 | Ovens
    Need part number for oven bulb
    looked up the bulb part is no longer available, but it looked like a regular appliance light bulb, remove the old one no diffrent then any appliance bulb you can buy in the supermarket if need be
    Feb 19, 2008 | Ovens
    Ovens Logo
    Top Ovens Experts
    ashburton
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
