Question about Casio Watches
I have Casio watch model EDIFICIE nodule No.4334 the problem is my analog not working but digital run a well could you help me what is the solution for this issue thanks Karis.F
SOURCE: analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Posted on Sep 27, 2007
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
Posted on Apr 11, 2008
SOURCE: Casio Wave Ceptor WVA-104H
works, thanks
Posted on May 09, 2008
  • 13433 Answers
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
escapement
  • 2334 Answers
SOURCE: how to set analog time on casio fishing gear watch
Follow this link and get manual:
Rate me, please.
Posted on Mar 15, 2009
On my casio edifice 4334 module and the digital works fine but the analog i can see the minutes handle trying to move but not succeeding , seems to me like it is stuck thanks in advance.
Check if the battery is still in good condition. If this doesn't solve the problem, swipe a magnet over the back of the watch in different directions until the minute hand moves. Take care not to scratch the watch with the magnet. It may be necessary to oscillate the magnet several times at the correct position and direction until the minute hand moves freely.
Sep 26, 2015 | Casio Watches
Casio CPW-500H-1AV analog watch not working
That certainly wouldn't hurt - be sure you use good new batteries.
Aug 06, 2014 | Casio Watches
I have a wrist watch casio g-shock model g-511d-7avdr and then i don't know how to set the analog time...how can this one?i am looking for the manual but lost it.
Analog time follows digital time.
For manual,check the link below using the module nbr (4 digit nbr in a frame on the back cover).
Timepieces Watches Manuals CASIO
Oct 11, 2013 | Casio Watches
I have a casio tough solar watch. Model LCF-30/ module 2790:I need to set the time, both analog and digital. Lost my manual. Please help
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Jul 29, 2011 | Casio Classic LCF30-1B Watch for Women
The brand new Casio watch Module No. 2747 does not allow the analog time to be decreased! I've reset the digital time to the present time. When I try to reset the analog time (watch hands) I cannot turn...
Assuming all Casio models have the same mode of operation, try this:-
Press the mode button until you see "HS" on the display (hand setting) and then use the 2 and 4 o'clock buttons to adjest the hands.
If this does not work and you do not have the manual for your watch,you can get
watches;
Accept terms
y
Dec 23, 2010 | Watches
English Manual for the Casio watch model AQ-163W-1B1JF
Select "support" and the "manuals", watches;
Accept terms
Click on "search" and the download your instructions.
Feb 11, 2010 | Casio Analog Digital Chronograph Alarm...
I cant set analogue time on casio hd wrist
Follow this link:
Rate, please.
Mar 30, 2009 | Casio WVA430A-1AV Wrist Watch
Analog will not sync with digital
Dear I received gift of G-300 Casio watch but could not adjust the analog time where as digital time adjusted. Could you please help me to guide for adjsuting its Analog time.
Regards,
Tahir Khan
Feb 14, 2008 | Watches
Setting time on casio illuminator watch
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Dec 03, 2007 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
118 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
