Question about Refrigerators
Frig running but warm - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 22, 2011
Kenmore 596.73503201 frig warm, freezer working
Check your duct from freezer section is open if it is check that fan is running ,if it's not the fan is faulty and needs to be replaced
Jan 10, 2014 | Kenmore 73503 Stainless Steel Bottom...
The engine is still running, but the frig is warm a friend turned the timer and the freezer is freezing now, but the frig is still warm. Do I need a new timer?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Seems like the top half of the refrigerator is not cooling and the icemaker is not working
What is the temp. of the freezer section?
not cooling means warm. these are the possibilities if you have a warm freezer
compressor not running
freezer fan not running
conderser fan not running
frig stuck in defrost mode
bad thermostat stuck open
no power to the frig.
water valve bad
water shutoff line clogged
these are some of the possibilities if you are not inclined to troubleshoot then you have to call someone if you can check let me know if you think you found the problem and i will tell you how to fix it thanks
Mar 28, 2010 | Refrigerators
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
Hotpoint frig,top freezer motor runs contiunally, thermostat set in middle of temp. control. side of frig stays cool all time.[does not get warm as it used to] is defrost thermostat bad or timer?
niether. is there frost on back wall of freezer? if no look behind back wall and see if there is frost on all the coils when running. if less than 80% is frosty...freon. or is there frost covering back panel..if so then defrost problem would be correct. but side would be warm so I think not.
Jun 12, 2009 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Fridge is warm
Hi!!! you have 2 problems that are causing your frig not to cool.First one is a seal seal problem,make sure that the compressor is running and the inside fan motor and the condensor fan motor locaated behind the frig..if the are then you have a seal system problem ,most likely a freon like or restriction..Second you could have a defrost problem open the freezer door and look bank on the wall of the evaporator if you see frost or ice then you have a defrost problem..Just replace the defrost timer and you should be fine..remember to defrost frig when installing defrost timer.Good luck.
Jan 04, 2009 | Refrigerators
Frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
