Question about Cell Phones
I do not have the user manual for my Fuse Bluetooth from fonegear. Where can I download a manual from. I figured out how to pair it with my phone but from then on I'm lost. My phone is a Motorola Q Thanks. Christina
  • 492 Answers
Two places will help you. Motorola.com and whichever carrier you use (T-mobile, Sprint, Verison, AT&T, etc.) You can download the PDF file free of charge.
Posted on Mar 22, 2011
I got a Sharper Image Bluetooth speaker system and it didn't come with a manual, I can't figure out how to set anything, (radio stations, bluetooth pairing, clock etc) it asks for a code when pairing
easy put your phone or device on and the other device look for it in the scanning option and pair its normaly asks for a pin that is the pin they give you with the phone for the bluetooth option 00000 is standard
Dec 28, 2013 | Sharper Image Portable Speaker System Dock...
I need the english manual for the fonegear mini Blu headset
try here. bought mine used and they changed the password. now to figure out how to change that. hope this helps. 3's
Grampa
http://www.manualslib.com/manual/251101/Fonegear-976.html#manual
Feb 19, 2013 | foneGEAR (00976) Wireless Headset
How to connect to phone
Pairing the Headset
*You are required to pair the headset with your mobile phone or other device before using it.
1. Ensure the headset is off, then press down the P2 button until the pairing mode (both Blue & Red-LED's are flashing
alternately), then release. This will take about 6 seconds.
2. Initiate pairing process of your mobile phone. Refer to the manual of the mobile phone for the direction. You will see a new
item "BT headset" added in your Bluetooth device list after the searching process.
3. You will be asked to enter a pin code to complete the pairing. Enter 1234 and confirm. (Note: the 1234 is a default pin code
pre-stored in the Headset) The red indication will turn off and the blue indicator will flash slowly after the paring is completed
successfully.
4. Once the pairing is complete, the Red LED will turn off and the Blue LED will begin blinking, (indicating standby mode). If it is
not finished paring within 2 minutes, the headset will go into standby mode, and pairing is unavailable. You will need to restart
and repeat steps 1-3.
MANUAL HERE:
Oct 04, 2012 | foneGEAR (00976) Wireless Headset
Cobra Bluetooth CB pairing problems
Did you hold the BT button for 4 seconds or for 6?
I would try it starting fresh- first without pulling the fuse and then with pulling the fuse first and waiting about 10 minutes before installing the fuse again. Then start with the procedure as if it never had been connected to a blue tooth phone.
If you do not have the manual anymore, it can be downloaded here:
https://www.cobra.com/downloads/29WXNWBT_MANL.pdf
Even if you have a different model CB, Cobra uses the same setup for most of their line.
Feb 14, 2012 | Cobra Radio Communications
How can i reactivate my blueant blue tooth on my motorola ic902?
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Default code for bluetooh pairing.
the most popular ones are 1234, 0000, 8888. If this doesnt do it then consult the user manual.
Nov 27, 2008 | LG enV VX9900 Cellular Phone
Cell Phones Logo
339 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
