Question about Tasco Essentials 10x50 2023BRZ Wide Angle WA Zip Focus Binoculars
What do I use and how do I lubricate the stiff focussing knob on my Zip Focus 10X50 tasco binocs?
5 Suggested Answers
  • 14 Answers
SOURCE: my lens is out on my tasco 10x50 mm zip focus 2023 brz wideangle
Crazy glue will sometimes leave a white cloudy film on the glass surface. I've had good luck with www.binocularservice.com and they are very reasonable too.
Posted on Jun 17, 2008
  • 112 Answers
SOURCE: Stiff focussing wheel on Zeiss binoculars
like me and you with age we all get stiff...sounds like it has been used alot and needs regreasing. the focus wheel on the zeiss is a double washer type and that it why it is stiff, sometimes the washer between the two focus knobs gets broken....but im sure thats not it...just needs a little tlc ..if i can help any further give me a call @15082549726....surprised zeissman didnt answer thi
Posted on Aug 06, 2009
o0zappa0o
  • 7 Answers
SOURCE: The adjustment knob was very hard to turn. Any way to lubricate?
I would be inclined to use a penatrative aerosol lubricant (like WD-40) in very sparse quantities. Squirt a little in using the WD40 smart straw applicator to direct the lube accurately and work the adjuster back and forth in a small section. Repeat this until you have freed up the adjustment from one end of its scope to the other. The focal adjustment is typically housed separately to the lenses and careful application of the lube should not affect them - avoid overusing the lube and have a mopup cloth under the spray zone to keep overspray/drips to an absolute minimum.
Posted on Aug 18, 2009
LongPockets
  • 1177 Answers
SOURCE: My Tasco 10x50 InFocus Binoculars
This is normal I'm afraid. "InFocus" is a brand name indicating that these are fixed focus. The name implies that they are magically always in focus, but actually means that they CAN'T be focussed. They have a fixed compromise focus setting that is OK but maybe not brilliant from far distance to fairly close, but actually only completely right at some point in between. If you want binoculars to use for much closer viewing than the compromise distance, you need to buy some with a focussing knob.
Posted on Dec 09, 2010
I have a makusutove 150 1800 telescope and I cant seem to get it to focus correctly - it seems as though the mirrors are focussing the light behind the viewing lens. I can get a focussed image if I hold...
You do not have enough BACK-FOCUS, you need an extension tube for the focuser like this one:
http://www.skiesunlimited.net/index.php?CategoryID=132
Buy the correct size for the focuser hole--
Jan 21, 2011 | Tasco 49114500 Spacestation(r) 114mm...
My EL 8.5 x 42 binoc's are approx 5 yrs old. The focus wheel has become very stiff. Is there a way to fix this myself?
No. It's best to have them repaired by Swarovski. There should be no cost involved other than postage.
Jan 10, 2010 | Swarovski Optik Optics
I see double one over the other about 20 degrees
Up close to the eyepieces around the barrels are small screws that you can use to "collaminate" your binocs. The screws aren't meant to be accessed by the owner and most manufacturers cover them up with the material that surrounds the binocs. Of course the binocs in their current state are useless anyhow, so I wouldn't hesitate to peel up the material to look for the screws. If you do it carefully, you can reseat the material anyhow. Then once you locate the small screws, put the binocs on a stand or a table outside. Focus on something far away using one eye. Then using both eyes, you adjust the screw on the other eyepiece while looking through the binocs. Adjust until you get a single image. You can use loctite, or nail polish to "glue" the screw in the final position if it is really loose.
Apr 23, 2009 | Steiner Tasco Offshore 54 Binoculars
Apr 10, 2009 | Optics
Out of focus
Assuming you are focussing correctly. When binoculars are out of collimation the most usual effect is double vision as the optical axis do not line up. The only thing you can do is to take them to a binocular repairer. The problem is the cost. Proper repair need the use of a device known as a collimator and it is a laborious task to do it properly. Your binoculars do not carry a high monetary value and a proper repair will cost more than a new binocular of similar specs. Porro prism binoculars mostly have the objective lenses set further apart than the eyepieces. This holds true except for reverse porro prisms which are the other way round. Roof prisms have both the front and rear lenses inline.
Make sure when you focus that the first eye you use to focus with is the one where the eyepiece does not have its own focus ring (dioptre). The dioptre adjustment is on either the left or the right depending on the brand. That eyepiece should be left alone until you have focused using the center ring. Then leave the center ring alone and focus the eyepiece that has the adjustment ring.
Mar 12, 2009 | Optics
My lens is out on my tasco 10x50 mm zip focus 2023 brz wideangle , I just bought these used and the lens was out but I have it, how can i get it to stay in place?
Jun 04, 2008 | Tasco Optics
Focussing
All of Tasco's manuals are on this web site-
http://www.tasco.com/pages/instruction-manuals/
Put the eyepiece with the largest number written on it into the focuser-- do not use the 2x barlow if you have one. Practice focusing with this eyepiece during the day time on a distant object like a telephone pole or a building.
www.telescopeman.org
www.telescopeman.us
Apr 07, 2008 | Tasco Galaxsee 46114375 (375 x 114mm)...
Focus Issues
Try tightening the grub screw that fastens the knob onto the shft that it turns.
Better still, buy a flexible extended focusser which makes focussing much easier. Check on eBay for "Meade flexible focus"
Sep 27, 2007 | Meade Telescope
Double vision
The distance between the centers of the eyepieces of your binocular must be the same as the distance between your pupils. This distance is adjusted as follows: 1. Focus on a distant object. 2. Pivot the two halves of your binocular farther or closer apart until you can see a single unobstructed, circular field of view. Make sure to focus on a distant object when you do this because when you focus on a close object you always see two slightly overlapping circular fields. Your binocular may have a scale on the top, between the eyepieces, to help you remember this setting.
Jul 03, 2007 | Bushnell Powerview - Compact 10 x 25...
Internal cleaning
I don't know about disassembling binoculars. However have you tried drying them out, either in a "dry box" or by using silica crystals?
May 06, 2007 | Tasco Essentials 10x50 2023BRZ Wide Angle...
Tasco Essentials 10x50 2023BRZ Wide Angle WA Zip Focus Binoculars Logo
63 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Lyle Siemens
Lyle Siemens
Are you a Tasco Optic Expert? Answer questions, earn points and help others
