Question about Archos 7 Digital Media Player
My arcos no working teh touch screen so bad because for example u press a dive k d q etc
    New Friend:
This is how I solved the problem with the touch panel as of this time....
The first solution, the additional cable from Archos website or manual
Attach this cable to the archos, wait for a 10 seconds then the touch screen would work. If the cable won't work attach a wired mouse.
The second solution is a female to female usb. (If you don't have the additional cable from the website or the manual.)
Attached the cable that comes with your archos then the female to female usb adaptor, wait for a few seconds then the touch panel would work again. If it doesn't work attach the wired mouse wait for a few seconds until the archos recognizes the wired mouse. (
I hope this works to all archos.
Posted on Jan 08, 2013
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
I believe you are trying to say that your touch screen isn't working. Your touch screen is probably locked. Its similar to a button hold lock, when this is activated, you can't press any buttons do anything unless you unlock it. To unlock the touch screen, press the ON/OFF button (don't hold the button for a long period of time. A message will appear on your screen asking for your conformation (approval) to perform the task. If that doesn't work, tap the TOOLS option, then select SETTINGS, and choose SCREEN. Once you've done that, choose the "Touch Screen Calibration" button and follow on-screen instructions given. If the second solution doesn't work, the "Touch Screen Calibration" option can be forced by using a feature called 'System Recovery'. To do a system recovery, Press and hold the Power button, then the Volume + button as soon as possible until you see a white screen, as system recovery is beginning. While this is happening, you will not be able to use the touchscreen to navigate between items. In order to navigate between items, you will have to use the Volume + & Volume - buttons and use the Power button to validate your selected task. The system recovery feature gives you a lot of options. Select the "Touch Screen Calibration" option and follow on-screen instructions given. I hope this activates your touch screen again.
Posted on Mar 22, 2011
Ricoh aficio MP c3000 touch screen: displays, printer reacts to physicly pressed keys (number of copies changes on the screen etc), prints scans but does not react to touching the screen
the touch screen might be out of order, or if just when yo press something specific , as example the tray 1, an it react as you pressed something else then the touch screen need calibration. you can enter the calibration process by pressing in this right order the next buttons. first press once the yellow key then press 1993 and then press the red stop key 5 times and the lest 5th hold it for 10 seconds, after you release it press the blue number key pad 1 and then adjust the screen as it request the machine from you one order then other till the end for more info please write more info..
Oct 02, 2016 | Ricoh Office Equipment & Supplies
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Feb 07, 2014 | Minolta bizhub 200 Copier
Touch screen has stopped functioning after only two weeks. Numbers are all out of position etc. For example, press 2 to get 5, in contacts press name above the one you want and then it wont call the person...
toutch screen missed alignment. I can't verify what model you have, but for some model, like Garmin, you could reset to factory mode by hold your finger tip in right&bottom corner of screen, then power up. after that you can do alignment position by toutch cross mark
Mar 28, 2011 | GPS
How do i clear the hard dive
Here are teh steps to follow on how to format your PS3 hard drive:
• in the main menu screen, go to "Settings"
• the go to "System Settings"
• select "Format Utitility" under System Settings
• then select Format Hard Drive
• Select Yes to begin the format.
• Select Use All for the PS3 System.
• Select Quick Format.
• Select Yes. This will finalize the format. Then restart the system.
May 10, 2010 | Sony Playstation 3 (PS3) Console
I got a msg and couldn't use touch screen and nothing would work
u need a new phoen once the touch screen stops workin uneed a new phone yes thats the fault with touch screen fones or u can use teh navigations keys
Aug 09, 2009 | LG Xenon GR500 Cell Phone
Stuck VHS Tape/Power Issue
It sounds like the vcr is not completely loading the tape, and is overloading or getting confused. If you feel up to it, you can take the cover off the tv, find the tape loading mechanism, and 'help' the loading rollers along yourself... once the tape loads, eject it immediately, and you should be off and running again. Just be careful not to touch any electrical connections. If you're not comfortable with that, you're right, it's probably cheaper to get a newer tv - check with a local independent shop first, though, it should be a really quick fix.
Mar 14, 2009 | Samsung Televison & Video
Nintendo ds lite
First try to recalibrate the screen (start up the DS, and do the following--text from nintendo.com):
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
    • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
    • Ifthe touch screen is not responding properly, hold the Nintendo DS at anangle so that you can see where the edges of the Touch Screen meet thehousing of the system. Look around the entire edge of the Touch Screenfor any foreign material (such as crumbs, etc.) that may be wedged inbetween the Touch Screen and the housing of the DS. Foreign material inthis area can cause the Touch Screen to work incorrectly.
If the screen still does not work, you need to buy a new touchscreen. Many vendors sell these, here's an example:
http://store.richspsxparts.com/nidslito.html
You will need a good tri-wing screwdriver to do this repair (don't buy a cheap knockoff--they will strip your screws). Try one like this: http://www.play-asia.com/paOS-13-71-1e-49-en-15-tri_wing-70-1fe.html
Then follow the step by step tutorial at:
http://www.instructables.com/id/Repairing-a-Nintendo-DS-Lite/
Dec 07, 2008 | Nintendo DS Lite Console
Sound still coming from arcos when headphoes are pluged in
Touch the right side of the screen to bring up the side menu. Touch the wrench/cog "settings" icon. Touch "sound". On this screen scroll the "Built-in-speaker" line until it says "Automatic" rather than "on". This should fix your problem.
Nov 30, 2008 | Archos 605 WiFi Digital Media Player
Image Runner 400
The touch screen needs calibrated in service mode
It is easy to press buttons you shouldnt when in service mode which can cause an expensive service call. Do you have experience working on Canon copiers?
I can help but do not want to cause serious problems...
Nov 30, 2007 | Canon imageRUNNER 5570 Copier
Archos 7 Digital Media Player Logo
304 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
