Question about Dell Inspiron 1525 Notebook
SD/MMC card is not getting detected. SOmetimes it works but sometimes it doesn't please advise.
I would like you to check www.dellsupport.com for some updates which you can download for the card reader and motherboard bios, and its chipset. kindly update these devices. if all fails then card reader needs replacement.
Posted on May 23, 2011
Sd ms pro mmc sm xd dv 8000 slot is not recognizing card
Try a different sd card,, chances are your card needs to be replaced.. yes they go bad, sometimes very quickly.
Dec 30, 2012 | HP Pavilion dv8000 Series Laptop DVD Drive...
Sandisk sdhc card
The C875 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Jun 10, 2012 | Kodak EasyShare C875 Digital Camera
I cant open my sd/mmc card reader and writer.
Some SD and MMC have a security feature in them. If so you will need the disk that came along with it. After you install it then that's the time you can fully utilize your SD/MMC. SD means Secure Data / MMC means Multi Media Card.
If your card reader is not appearing in the My Computer then check if it is detected in the Windows device manager. Go to START > CONTROL PANEL > DEVICE MANAGER. Usually it is under the category of Disk Adapters or Human Interface Device. If it's not present then unplug and plug the device back in. Or try a different USB port to see if that will work. If it doesn't then most likely the reader is defective. But if it is detected and still not able to read the SD/MMC and the SD is being read by a different computer then the issue could be that the SD is not compatible with the reader.
Jun 08, 2011 | Computers & Internet
I have not been able to format SanDisk SDHC 4GB Memory Card on my Kodak Easyshare Digital Camera C530. I am regularly getting the message "FILESYS ERROR e00100. The Memory card is authintic & NOT...
The C530 uses MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
Nov 01, 2010 | Kodak EasyShare C315 Digital Camera
I just bought a HTC Tattoo and got a micro SD caed with it. So i want to put some music in the card so i can play it on my cell, but when i put my USB cable from the cell where the SD card is in, my laptop...
hi
well sometimes it happens that laptops or desktops cant read a phone's micro sd card from usb cable so the easiest way is to download a software for your htc!this can be use to make the laptop recognised your phone or else just get a sd/mmc/rs-mmc usb card reader..just put your micro sd in the mmc card reader and plug it in your laptop as a usb pen dirve!!This method is simple, fast and easy..
May 18, 2010 | Cell Phones
I attach Nikon CoolPix S550 (off) directly to USB port of iMac (OS 10.5.8), then turn camera on. Nikon Transfer (Preferences set to launch when camera is attached) does not launch. No sign appears on...
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
  • You connect your digital camera that uses SD/MMC card to a Macintosh computer in 'Disk Drive' mode
  • You switch to 'Digital Camera' mode and observe that the camera is no longer recognized by iPhoto or Image Capture
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
  • Connect the camera in 'Disk Drive' mode or use FireWaire or USB card reader to access the card.
  • Backup all the files to your system
  • Use your digital camera to reformat the card.
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
Nov 25, 2009 | Cameras
Can i insert this type of memory card into the slot into the computer directly? it says on my laptop that sd, xd and M (symbol for pro duo? )can be inserted. But when i try to insert it, it doesn't appear...
it is advisable to buy a AIO (All in one) card reader, you can use this to many different type of memory card, the built in slot for memory card in your laptop sometimes only suite to a single type or model (ex. SD slot..MMC Slot etc.)
in your case your memory card is not fit to it, don't force it you might damaged your card
Nov 01, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
6600 MMC not detected in Laptop
Ur Memory Card Has the ERROR i.e : Its Corrupted -
Ur Memory Card might Contain Viruses or Autorun fault -
U Should Format ur Mem. Card from Mobile then PC then Mobile -
Like dis way it will Work both in Mobile as well as in PC -
Jan 14, 2009 | Nokia 6600
My media player won't detect my mini sd card, but my mp3 will
Sometimes it appears that it does not detect it, but goo to your bottom left corner of your computer screen, click on the start, and then go to "computer" and click on it, now look under "storage devices" it should appear there. look for the device that wasn't there before, sometimes the name changes.
Dec 25, 2008 | SanDisk Sansa e250 MP3 Player
Sanyo VPC-S750 CAMERA
I have a sanyo vpc-s750 and have had my computer rebuilt with windows vista due to it crashing. I lost all the software for the camera set up..can you please help me as i have lots of photos on my camera which i wish to upload onto the computer. I am going crazy, everything I try does not work.
Please help me. many thanks, Rosemary gorodecky
Feb 21, 2008 | Sanyo VPC-E760 Digital Camera
Dell Inspiron 1525 Notebook Logo
100 people viewed this question
Alun Cox
