Question about Korg SP-250
KORG SP-250. Keyboard powers up, you can change all selections, five or six random notes sound, but the other keys produce no sound at all.
  • Korg Master
  • 5,603 Answers
There is probably a cable loose that connects the keyboard itself to the processor... OR the key contacts have been contaminated by spilled liquid. The keys are scanned as a matrix. The contacts will be a conductive rubber pressed against circuit board traces. Clean contact "pills" and the circuit traces with ONLY 99% isoprophyl alcohol.
This is NOT for the unskilled to attempt a DIY other than carefully opening and looking for a cable that has come loose.
Posted on Mar 22, 2011
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
How do I restore a dead key on a Korg X5?
What do you mean by applied graphite...graphite powder? That is not the solution I wouldn't think, you need to use a keyboard contact repair kit, which has a solution you paint on? Something like the link provided might be in order. Make sure there are no improper conductive bridges formed between the contacts in the PCB board surfaces. Replacement rubber pads (the part that presses down) are available from any decent service provider (try Syntaur if can't find http://syntaur.com/korg_x.html ) (beneath key) Korg Key Contact Repair Kit Replacement Keys and Parts for Korg Series Keyboards
Jan 14, 2015 | Korg Music
Some keys wont work after my korg pa50sd is turned on
It's about hardwares.
If dead keys are the same notes(C2-C3-C4 or E2-E3-E5 etc),its electronic parts problem.
If dead keys are random(D1-F1-G3-B5 etc),chances are :
  • Rubber keypads is break. Below the keyboard. Replace it.
  • Dust can cause bad contact the carbon inside the rubber keypad. Clean it.
Jun 13, 2014 | Korg Pa50 Professional Arranger Keyboard...
How to change a fuse on a korg Sp-250
There is no fuse inside SP250. If the unit can't power ON,there maybe damage to the adapter,adapter cord/connector,or broken fuse inside the adapter.
If adapter is in good condition, then the damage is inside SP250.
The possibilities are on regulator section.
Check all parts in this section (figure 1).
Also maybe there is a broken soldering joints at DC input socket.
change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-0.jpg change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-1.jpgchange-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-3.jpg
Jun 01, 2014 | Korg SP-250
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Korg sp-250 randomly changes the voicing
When was the last time you changed the batteries? You may have gotten a pack of expired batteries the last time you replaced them. I suggest changing batteries.Jimmy
Apr 08, 2012 | Korg SP-250
Sp250 right outout seems to have broken and as a result there is no sound coming from the speakers on the keyboard or through the PA. If we use the left output through the PA - it works, Could you advise...
Check if headphone jack also has right channel dead... If headphones work on both channels, switch contacts on headphone jack MIGHT be the problem.
Jan 17, 2011 | Korg SP-250
Korg SP-250 Logo
543 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Wbix
Are you a Korg Music Expert? Answer questions, earn points and help others
