Question about Video Game Consoles & Games
My PS3 says "your hard
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 48 Answers
A ) Call Sony and have them send a new one.(last resort)
(however you may break your warrenty by following some of theese steps)
b ) Buy a laptop HDD and install it yourself. (I heard these are relatively cheap, and easy to replace.)
c ) Remove the drive, place it in a computer and format it. Return the drive to the PS3 and see if it will take.
OR
I have found a post for you; (someone with the same problem)
Hey, I had the same thing happen. The first two times it happened, the restore worked, and I was able to continue using the system. A few weeks later, I received the error, and the restore wouldn't take, it would just reset and come back to the same error. I fixed it with the following steps. 1. Took out the PS3 HDD (clicked open the cover, unscrewed the blue screw, slid drive towards the front) 2. Opened up my WD External USB drive case (runs on a 2.5" HDD) 3. Plugged the PS3 HDD into the USB case, and plugged it into my PC. 4. Ran the diskmgmt.msc from the Windows RUN in the START Menu 5. Once the drive came up, I had to right-click on it and initialize it, this gave it a drive letter. 6. Then I downloaded this little app : (http://www.ridgecrop.demon.co.uk/download/fat32format.zip). 7. Extracted it, and ran the following command in a DOS prompt: fat32 format e: ***obviously replacing the e: with the drive letter you saw in the disk management window. 8. Plugged the HDD back into the Ps3, and it formatted it to it's filesystem, and all was well. PS. I found these steps on http://www.ps3forums.com/archive/index.php/t-41928.html Honestly it was pretty simple, the hardest part was crackinig open my external USB drive, as I didn't want to ruin it's shiny case http://www.wdc.com/global/products/imageviewer.asp?model=wdfPassport_Portable_2&filter=31796&currentimage=frnt&lang=en This post is a little old, but it took me a while to find it.
Posted on Mar 22, 2011
PS3 says ''The hard disk's file system is corrupted and will be restored'' We press OK and the system says its restoring. When restored it comes up with the same message.
You need to restore your hard drive manually by connecting your hard drive to a computer, once installed you must select the hard drive and format it. once done you must format again but as FAT 32 and Done
For more help check us out at
www.1RepairStop.com
We Fix Everything
Aug 31, 2011 | Sony Playstation 3 (PS3) Console
My ps3 says " the
Let the PS3 restore itself. Your hard disk is corrupted unless you restore it you will not be able to use your PS3
Mar 03, 2011 | Sony Playstation 3 (PS3) Console
My ps3 is not working and this message apearrs "
Sounds like a bad hard disk. You might try to format the disk. If that does not help, you will have to purchase a new one.
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
My PS3 starts up but then says "The hard disk file
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, has crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 26, 2011 | Sony Playstation 3 (PS3) Console
The hard disk's file system is corrupted and will be restored. I clicked ok to restore system,but system cycles and repeats itself
More than likely the hard drive has bad sectors, that's why it's looping.
Just swap the drive out with ANY 2.5 inch SATA laptop hard drive. They sell 250gb drives from Best Buy for around $50.
Just swap, turn the console back on, and follow the instructions displayed by the PS3 ;)
Aug 14, 2010 | Sony Playstation 3 (PS3) Console
Ps3 help
This simply means...your hard disk is corrupted
I recommend replacing the Hard Disk, which is not difficult, here are some cheap hard disks
http://www.google.com/products?hl=en&client=opera&hs=eeZ&rls=en&q=ps3%20hard%20drive&um=1&ie=UTF-8&sa=N&tab=wf
and how to replace it
http://www.gamespot.com/features/6176090/index.html
Aug 02, 2010 | Sony PlayStation® 3 (60 GB) Console
Carried out an update, but now stuck in loop
Procedure for Entering Safe mode when PS3 is caught in update loop:
When you first turn on the PS3, it will not allow you to go into Safe mode. You must prepare it for this.
link for flash drive prep:
http://www.us.playstation.com/Support/SystemUpdates/PS3/pc_update.html#update_PC
(This will not work for the drive that currently is caught in the update loop. You must take the hard drive out of the PS3 and temporarily replace it with another 2.5” SATA drive. Note: temp drive may need to be initialized… Connect drive to pc, right click on My Computer and select Manage… Then select disk Management… you will then be presented with a dialogue box that will assist in initializing the disk.. However, only initialize it… Do Not Format it!(waste of time) Once the disk is initialized disconnect it from external enclosure or shut down computer and remove disk)
From the top:
1.) Plug in PS3 and flip switch in back of PS3 to on. Red LED in front of PS3 should light up. Also, plug in Controller at this point.
2.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then a final beep and the PS3 will power off again and Red LED will be on
3.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then two beeps
4.) As soon as you hear the two beeps, hold PS button on Controller
a. You will then be presented with an options screen
i. Restart System -- leads back to update loop
ii. Restore Default Settings --
iii. Restore File System -- leads back to update loop (8002F14E)
iv. Rebuild Database --
v. Restore PS3 System --
vi. System Update -- will cause error
5.) You will then remove the temporary SATA drive from the PS3 and replace it with the hard drive that is caught in the update loo
6.) I am currently stuck attempting to Restore Default Settings and Im sure it will end in error, but i have to try all possible solutions.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Start up PS3
If you have tried it a few times it may be a damaged HDD. You can do two things. Buy a new HDD (2.5 inch SATA drive) or contact Sony and see what they have to say.
Jun 01, 2008 | Sony Playstation 3 (PS3) Console
Ps3 60gb system
If that does not work throw in a new hd!
May 22, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
42 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
