Question about Maytag Dryers
I have a maytag med5770tq0 Dryer that got a shoe stuck when it was drying. When the shoe got stuck, the dryer stoped working. I removed the shoe and now nothing but the light inside the dryer will come on. I have removed the back, but I cannot figure out how to remove the top of the dryer so that I can get inside to where the belt is. I would definitely like to know how to remove the top, and also any suggestions on possible fixes and probable cost. thanks
  • 3,018 Answers
Here is a couple pictures on the complete disassembly of the top of your dryer - Could be the belt. Belt cost is not to bad if you replace it yourself. The cost to have someone else come out and replace it will vary. Cross fingers the motor did not burn up.Hope this helps.
I have a maytag med5770tq0 Dryer that got a shoe - ironfist109_18.jpgironfist109_19.jpg
Posted on Mar 22, 2011
Maytag dryer tennis shoe got caught and stopped dryer,when you turn it on it sounds as if it is working but it isnt turning
You might try this:
First Shut the electric breaker off to the dryer for about 30 seconds and and then turn back on.
Next, Open the dryer door and inspect the switch that tells the dryer the door is closed. work it by hand just to make sure it is not stuck.
then try and Spin the timer controls to another setting and see if the other setting will work.
Sep 21, 2017 | Maytag Dryers
Maytag model #: med5770tq0 won't dry. Please help
Dear Emily.
Several problems.
First, did this dryer ever work properly hooked up as it is?
I mean hooked to the roof event?
If it used to work just fine, then I suspect the vent to the roof is clogged with lint and is not allowing the heat to escape.
If it never did work right,(for example: it is new to us) then I'd venture dryers are not supposed to vent their hot air that far away, they do not have a strong enough blower to push that air that distance.
Then, you might try to find another place to vent the hot air, with a total distance of only 10 feet from the dryer, even if you only vented it while you were actually drying clothers.
I doubt if the last item is for you, but I have sometimes seen where the washing machine did not spin all the water out of the clothes, and then the dryer needed all day to get the clothes dry.
Be blessed.
Apr 17, 2013 | Maytag Dryers
Dryer will not restart after tennis shoe getting stuck in it
Make sure door is closed firmly. Try to Press and hold the START Button for 4-5 Seconds.
Good Luck and have a nice day.
Jun 29, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Thumping noise (similar to shoes drying) and burnt smell
that one needs a serviceman to look at it too many variables as to cause
Jan 23, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Neptune dryer won't start/
I do not have that specific dryer but try these simple steps.
Maybe they will help you.
1. Shut the electric breaker off to the dryer for about 30 seconds and and back on.
2. Open the dryer door and inspect the switch that tells the dryer the door is closed. work it by hand just to make sure it is not stuck.
3. Spin the timer controls to another setting and see if the other setting will work.
That's all I've got for now...
May 20, 2009 | Maytag Neptune MDE6700A Electric Dryer
Maytag dryer model LDE8410acw
Hi james,
How old is the dryer?
Sounds like a bad element!
Age determines if it's worth the investment !
Sep 18, 2008 | Maytag MDG9606 Dryer
Kemore Elite Oasis Dryer Error Code "AF?"
Problem solved! We read on here about someone else addressing the AF code by removing the back panel and fixing the pully that had come off. Belt was fine, with pully back in place dryer now works perfectly again. Thank you for saving us so much time and money!
Jun 14, 2008 | Kenmore 67082 Electric Dryer
Dryer stop drying
Check you venting,on gas units call for service.
Mar 17, 2008 | Maytag MDE2600 Electric Dryer
Dryers Logo
124 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
