Question about Fujitronic FA1400 Air Conditioner
I have the fujitronic 1400 portable a/c. The problem is when I turn it on it will run for half an hour sometimes more some times less and then it just shuts off. Also I noticed that some times when I touch the side of the unit it will cause it to turn off or on and im not touching anywhere near the control panel. not sure if that is related to the problem. any help is greatly appreciated.
4 Suggested Answers
  • 588 Answers
SOURCE: No Cooling
The water pump or the float valve is not working.
Posted on Aug 10, 2009
micromatikal
  • 2777 Answers
SOURCE: Hello, I have a Fujitronic FA1300 portable AC unit
This is the main control board in the AC unit malfunctioning. It thinks either the unit has been opened, or switched mode, which obviously it has not. If you have tried resetting it multiple times to no avail then it unfortunately needs a replacement board :(. If it were me, I would first call Fujitronic to see how they can help you proceed from your current position. Their number is 866-829-6666
Unfortunately these fujitronics are notorious for having issues like this, hopefully yours may still be under warranty.
Thanks
Tim
Posted on Sep 29, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: I have a Fujitronic FH-700B
SOUNDS LIKE THE MOTOR NEEDS OIL...LOOK FOR ZOOM OIL THIS LITTLE GUY IS A LIFE SAVER.. IT COULD ALSO BE FAN HITTING SHROUD, AND WILL CURE ITSSELF OVER TIME, BUT A OLD UNIT I THINK NEEDS THE FAN OILED..HOPE I WAS OF HELP. HIT THAT YES BUTTON IF'N I WAS .. JAY MOTOR GUY
Posted on Jul 21, 2011
Trying to set my garden leisure spa on sleep so it circulates less. Currently it turn on every hour and runs for 7 minutes.My electric bill is out the roof.
there is a thing called a switch that you can activate to turn it off unless you are using it
That saves about 85% of the power bill
retime the timer to run at longer periods for less time or fit your own timer in the lead to the pump
Apr 20, 2017 | Leisure Pool & Spa
I have a Fujitronic FH-700B Portable A/C unit that is squealing when I press the Cooler button. I can't find any help or support online as the item is no longer sold - is there a manual or...
Jul 21, 2011 | Fujitronic Heating & Cooling
Only half an hour ups works.
an UPS is only designed to prevent data loss while transitioning from grid to generator power.
They run on battery. Some work for as few as 10 minutes. Others as long as an hour.
Like all batteries, if overused, the 'last' time can become less and less.
Otherwise, I'd have to know make and model to be of more assistance.
Jul 19, 2011 | Computers & Internet
My Samsung 52 inch 240 HZ connected to a serious audio system keeps pausing to a black screen for 2 or 3 seconds. It does this about 1 time every half hour, sometimes more often, sometimes less. no...
run the television off a completely different power source than the sound equipment and see if it still happens.The line voltage could be pulled down by heavy current draw,and other issues.
Jan 03, 2011 | Televison & Video
Fujitronic fr eh8
http://www.fujitronic.com/freh8.php That's the link to their website, it makes out like the manual is available, but there is no link to click. Maybe they will add it in time?
Jul 20, 2010 | Fujitronic FR-EH8 8-Cup Rice Cooker
No Cooling
Aug 02, 2009 | Fujitronic FH-797 Portable Air Conditioner
Maytag refrigerater
If you have an ice maker in the freezer compartment try raising the bail arm and shutting it off. It is possible that an ice maker will increase your run time.
May 16, 2008 | Maytag Refrigerators
Half Screen went black
Try to replace the Logic board.
Dec 17, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Mitusbishi big screen vs-60707, circa 2001
I have never worked on a Mitsubishi with this problem but I have seen it in other sets. Most notably Zenith sets from about the same time. The Zenith sets have an electrolytic capacitor which fails (changes value) and causes the power supply to switch at a lower frequency. If the frequency is low enough the set will never turn on but if it is not less than half the operating frequency the set may turn on sometimes and run forever or not. It sounds like your Mitsu has a similar problem. This would not be an expensive fix but probably is beyond your expertise.
May 18, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Fujitronic FA1400 Air Conditioner Logo
29 people viewed this question
Top Fujitronic Heating & Cooling Experts
Bill Long
Jay Finke
Jay Finke
Are you a Fujitronic Heating and Cooling Expert? Answer questions, earn points and help others
