After turning on computer it shows a pop up saying Error (unable to find resource file)
    Master:
  • 525 Answers
You have a registry error. Go to START>RUN and type in cmd. Type in CHKDSK /R. Restart your computer and let it run.
Posted on Mar 22, 2011
Clkern.dll was loaded,but the dll register server entry point was not found.this file can not be registered
http://www.fix-all-dll-errors.com/clkern.dll/
Once you go to the above link click "Fix dll errors now" button,
it will register the dll file for you.
Dec 29, 2010 | Car Audio & Video
I have a OLD came called Babyz (it was made in 1999) and i got it and installed it... But i cannot play it! When ever i click Babyz and try to open it a error message pops up and says "Sorry, Babyz could...
HI,
The thing is '.dll' type files are a lot of important to run any application and I think that the disk dont have it already in it so there might be a disk problem or this could be because its too old because modern versions of windows like vista, 7 or xp cannot play old games or apps. Your pc probably could play any of the modern games.
Best regards
Oct 11, 2010 | eGames Babyz for Windows
Unable to copy files to cd
sounds like the optics in the CD drive have bit the dust. replace your drive. you can get one for cheap at any computer store
Mar 27, 2009 | Dell OptiPlex GX270 PC Desktop
LSASS "Unable to Load Component" Error
I think because of the power failure, some parts in your hard drive are broken, bad sector may be.
So, when reinstalling, I suggest you to do full format, not a quick format. That way, the installation will recognize the place where bad sector is located, and will not put anything at that place.
Can not load component, usually because windows can not read from the disk.
Dec 07, 2008 | Microsoft Windows XP Professional
WRITE PROTECTION
There are a number of reasons why you are unable to delete files and you need to be sure that the file is no longer required before you delete it. If a file won't allow you to delete it, it can mean a program on your computer is using it.
However, you can try the following...........
The simple way is to reboot your computer in "Safe Mode." To do this, reboot your computer, as the computer is booting, repeatedly press F8 until the option to select safe mode appears. Select safe mode and allow the computer to fully boot. Safe mode only loads all the critical and vital software to support your operating system and not all the programs installed on your computer. When the computer has booted, look for the file you want to delete and try to remove it. If you are able to delete the file, you can now reboot the computer normally, simply by restarting.
If this does not work a more complicated way of removing the file is to use DOS or Command Mode. This will definitely allow you to delete the file but is tricky if you have not used Command Mode before. Command mode will allow you to delete the complete folder so if there are other files in the folder that you want to keep, be sure to either put them in a different folder or move the file you want to delete into its own separate folder. Using command mode is irreversible so be sure you don't delete anything you are likely to need.
I will call the folder you want to delete FRED, just to identify it. Make a note of exactly where it is located on your hard drive, for example
C:\WINDOWS\Resources\FRED
Restart the computer pressing F8 like you did for safe mode.
This time select 'Command Mode.'
This will open a screen that looks old fashioned and there will be a prompt that will say something like
C:\Documents and Settings\Your_name>
Type del C:\WINDOWS\Resources\FRED
This will delete the folder called FRED which will remove your write protected file.
Then just restart you computer normally, the file will have been successfully removed.
Mar 08, 2008 | Computers & Internet
Go 710
Hook the Tomtom using the USB cable to your computer. You should see the Tomtom drive under My Computer as a drive letter.
Backup all data from the Tomtom to a folder on your computer. Now select the Tomtom drive and right click, select properties, select tools, and then Check now. Allow the computer to fix any problems with the Tomtom drive. Once this is completed. Remove the USB cable and do a reset. Now turn on your Tomtom and it should work.
Dec 26, 2007 | Tomtom GO 910 GPS Receiver
Windows Xp installation
IRQL_NOT_LESS_OR_EQUAL is a hardware error.
might be processor is over heating or you have a bad ram.
please check this article for more explanation on this issue.
Oct 27, 2007 | Microsoft Windows XP Professional With...
My file showing unexpected error while opening.
they might help http://www.actionscript.org/resources/categories/Tutorials/
Sep 12, 2007 | Macromedia Flash MX
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
