Question about Yamaha HTR-3063
On my HTR-3063, I could not get it to come on. So, I unplugged all the cables and speaker wires, and I plugged it in without any plugs or wires, and it turned on. So I changed all my wires and HDMI cables, and back to the same problem. What's the deal?
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Add things one at a time until you identify the one component (probably a speaker) that is causing the problem.
Posted on Mar 22, 2011
Yamaha HTR-3063 AV Receiver has stopped working. I turned it on and the lcd screen scrambled, then sound cut out. Can I fix this?
Have you tried switching the unit on with no cables or speakers connected and yes the unit can be repaired no problem.
Jun 15, 2016 | Yamaha Audio Players & Recorders
My HTR 3063 is not producing any sound
The YPAO isn't on the 3063 model. only 4063 and up. If this is used and you can't get your money back, there is a firmware file here http://download.yamaha.com/search/product/?language=en&site=ca.yamaha.com&product_id=1436250 that can help get your receiver running correctly.
Apr 28, 2013 | Yamaha HTR-3063
No picture using my playstation 3 with my yamaha receiver htr 3063
you might have to reset the video output. hold down the power button for 5 seconds. It should beep and the iight will flash. wait a few seconds then turn it on.
Nov 16, 2011 | Yamaha HTR-3063
Speakers wont work on the htr-3063....worked 10 minutes before on the old receiver
check to see what ohm your speakers are using. I know the 3063 supports both 6 and 8 ohm but it is defaulted at 8.
Aug 16, 2011 | Yamaha HTR-3063
How do I connect a CD player to my Yamaha HTR-3063 receiver?
... in whatever manner it requires according to its manual. The Yam accepts just about anything.
http://www.retrevo.com/support/Yamaha-HTR-3063-Receivers-manual/id/23653ag915/t/2/
Aug 14, 2011 | Yamaha HTR-3063
Where can i get firmware download for yamaha htr-3063
Hi al_sha,
Please be informed that Yamaha did not release firmware that can be downloaded by users, however they provided a step by step procedure on how to update the version of your unit. Please visit this link to have the Firmware update procedure for Yamaha HTR-3063.
Hope it helps.
Thank you for using FixYa.
Jun 16, 2011 | Yamaha HTR-3063
How to solve a W 1 error on a Yamaha HTR-3063
Are we really talking about a HTR-3063?
Register and download the manual for free at retrevo.com
Strangely enough, that message is NOT documented in the HTR-3063 manual, but in another Yamaha manual (HTR-5063) it means the speaker being tested is believed to be Out of Phase, meaning wired incorrectly.
Your unit (HTR-3063) doesn
Feb 15, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
NO sound, display says CHECK SP cable? Just bought yamaha292 theater system with AV receiver HTR-6230, all speakers are wired, plug with 1 optical to my TV, selected the inputs and there's no sound. ...
Probably the speakers are not wired correctly. Check this by turning on the receiver without speakers connected. If the message is gone, issue was in the connection of speakers. Check that you have not short-wired the + and -.
Dec 13, 2009 | Yamaha HTR-6130 Receiver
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
Good luck
Feb 03, 2008 | Yamaha HTR-6030 Receiver
Yamaha HTR-3063 Logo
218 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
