Question about Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder
Can you record from a vhs tape recorder deck to the camera dvcam tape so you can then output to a computer?
  • 4,924 Answers
I think that is you have a fire wire cable ...you can export directly from your recorder deck to the computer ...The idea is to make the connection and after that use the windows movie maker ...to import from device ..and choose the recorder as the device to import from .....The issue is the cable ...cause you need a cable to fit the out-put of your recorder..and the input (firewire) on the computer ..
Same thing with the camera ...just a mater of cable ...cause you will no longer be able to use the cable for exporting from the camera ..but you need one from the exit of the deck ...into the video in-let of the camera ..and the actually importing is made by putting the recorder on playback ..and the camera on record..and also follow the signal to be received on the camera ..
same thing when you attach it directly to the computer ...open windows movie maker..and playback the deck ...while you open the import from device function ..and select the deck as the device to import from
Posted on Mar 22, 2011
Can DVD DISKS BE COPIED FROM VHS TAPES ON A dual; DECK MACHINE?
There are machines made just for that task such as the Magnavox DVD recorder. There is a VHS tape deck on one side and a DVD recorder on the other side. You can copy a VHS tape to a DVD and copy a DVD onto a VHS tape as well
Jan 21, 2017 | Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
Recording from the Mini DV to VHS Tape
Mini dv is a digital recording and VHS is analogue so they are incompatible. Does your camera have an analogue output? That is a lead that ends with something like RCA plugs or a Scart plug. Then you can feed the signal into a VHS recorder.
Aug 23, 2008 | Canon ZR45MC Mini DV Digital Camcorder
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Date and time display
the vhs is an analogue output which does not allow the digital time and date to be carried over: u need a digital output
Apr 12, 2008 | Canon MV750i Mini DV Digital Camcorder
Record from a VHS player
This is an easy one. It took me a while to figure it out too. You are on the right track but you need to use the remote control. You will go from record/pause to record and of course you have to use the mini to triple RCA cable that comes with the camera. I can't remember if there is an internal setting in the menu that needs to happen but I don't think so.
Videoteacher
Jan 07, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Camcorder Sony DSR-300 want to burn direct to DVD recorder
You can connect this directly to a DVD recorder. I suggest using S-Video and the two audio channels.
Sep 14, 2005 | Sony Dvcam DSR-300 Camcorder
Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
