Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears Garage Door opener lifts part way and stops. Connected to rail or not. Sensor circuits are working. I read that the RPM sensor would cause this if it's going down but this one is stopping while lifting.
    President:
  • 3,197 Answers
On the rear of the motor unit you will find the 'up force' adjustment. Increase this about 1/4 turn and try. It is also a good time to remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and it will be obvious if it is going bad. A bad RPM sensor will cause the door to stop when the door is opening and reverse to the open position when closing.
Posted on Mar 22, 2011
I have a Chamberlane Lift Master Professional I went to open it yesterday and it would not open. When the button is pushed the unit just clicks and the controller light is blinking 5 times then pauses and...
The code it is flashing is "RPM sensor or motor overload." It is not a door sensor problem. The RPM sensor is a small circuit board just in front of the motor.
Mar 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
I follow all your tips, but even due the garage door does not close because the sensors at the bootom of the rails are not align. I check high, eye dust, power, sensor ligths. But i do not find the way to...
If the main light on the motor unit flashes 10 times when the door reverses it is a door sensor problem. If not it could be the RPM sensor that is causing your problem. This is a small circuit board just in front of the motor. Try increasing the down force first. This is a control on the rear of the motor unit.
Jan 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
My opener is a 1/2 horse lift master professional chain drive . The door will not close unless you hold the closer button in. From the remote it will only move a few inches and then reverse. The door works...
If the main light flashes 10 times when the door reverses it is a door sensor problem. If not, you probably have a bad RPM sensor board which is a small printed circuit board just in front of the motor.
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
My craftsman door opener went up half way and stopped. Light on u nit was not on and indicator light flashed 5 times, the repeats 5 flashes. billybob
The code for that light flashing 5 times is 'motor overheated or RPM sensor failure'. The RPM sensor is a small printed circuit board just in front of the motor. Release the door from the opener and operate by hand. It should raise easily and should stay put when it is about waist high.
Dec 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
The garage door opener is not cycling all the way closed, before returning fully opened. It is traveling about two feet down before stopping and gong back to the opened position. There is no obstruction in...
If the main lights are flashing 10 times it is a door sensor problem. If the lights are not flashing it is a bad RPM sensor board which is a small printed circuit board just in front of the motor. It can be purchased at Sears or any good door opener service company.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not close with remote.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
Aug 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener (Unit run front & back only for 2 second)
Double check to make sure the sensors are wired correctly. The 2 solid white wires go to terminal 2 and the wires with black stripes go to terminal 3. If the wiring is correct then you possibly have a bad RPM sensor. The RPM sensor is a small circuit board just in front of the motor.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman garage opener
The blinking LED is sending the code for "RPM sensor or motor overload. It isn't the motor or it wouldn't run at all. The RPM sensor is a small printed circuit board near the front of the motor. It will be available at Sears or any good door opener service company.
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Garage Door Opener Problems...
The problem lies in the RPM sensor, most likely due to the interrupter cup assembly. The interrupter cup assembly is the black cap that runs through the RPM sensor. You may have forgotten to re-attach this piece or it is probably moving too far out when the garage sets in motion. To fix this, remove the cup assembly, unscrew the two screws on the top metal piece with a 1/8 allen wrench, push the metal piece as far in as possible and put the screws back on. This will give more room for the cup assembly to spin and be read by the RPM sensor. Hope this helps!
Feb 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
59 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
