Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Smel; smoke want come on anymore - RCA D52W20 52" Rear Projection HDTV-Ready Television
  • RCA Master
  • 8,617 Answers
That can be caused by several items with your model mainly components on the dfelection board. You can get replacement deflection boards from www.tvrepairworld.com the boards come with warranty and instructions to install the board.
Posted on Mar 22, 2011
How to increase the output voltage
Measure the Generator after 10 minutes the first measure but not only to one power outlet with doing a measure with a multimeter its not done so because the generator is fully unloaded then you will see 105 vac
Measure on one outlet and use a paint stipper a 2000 watt type and measure at the same time on the second power outlet with a multimeter on AC you should get more volts out to measure instead of 105 volts then you hear that its generate power and blow more smoke you will be seen a 115 or 120 volts if you increase this generator its possible you get if you are increase the idle power to 120 volt can create an over loading of 200 volt or more over the outlets that can give damage if it the stator electric field generate power outside its level it can blow up your expensive tools and in a short time you think there is not enough power on my tools anymore then your armatures are become bad and the tools are hot in a short time warmt dissipation has blow up armature and nothing smels hot but the tools are blowing up. and you see nothing inside because the tools will not are getting black burned and hot but the to high magnetic pulse burns the weak points inside the armature in a fraction of time.
Beware of that the adjusting is normally doing with a tacho meter and a suggestion of about 3000rpm and not more of the stator what its max depend on model . but adjust by the load power of a working paint stripper it can have enough if you adjust 120 volt by load.
Mar 06, 2016 | Electrical Supplies
Hi to all.I am thinking of buying a 2nd hand 2013 Suzuki APV SGX 1.6l Automatic with 19,000km mileage only. Everything is tiptop but when the engine is on, very visible white smoke comes out from tailpipe...
Is this your first car, or first year driving in winter?
are you in USA or canada? (we are a USA forum here so???)
if yes, Suzuki is chapter 11, here and getting many parts are a PAIN.
big pain. dont buy SUzuki cars. , in N.America. bingo !
but my guess you are not here, in USA or N.America
but are far from here, right? km is canada or outside here.
and x2 never buy smoking engines.
(i do but for dirty cheap and fix em)
white smoke smells like burning smoke, RUN,, lingers.long time it does.
Fast dissipated smoke, (it's not smoke sorry!)
is steam it's normal all cars do that and more cold, weather. all fuels burns to water as a byproduct of combustion, but will smell like exhaust only. (carbon and exh. smell, all very normal)
but if the steam continues, and smells of antifreeze and nasty
sweet smel,l RUN.
buy a Nissan. or Honda. never any Suzuki ever.
the question is ,where next will they go bankrupt. hummmmmmmmmmm
Mar 06, 2015 | Suzuki Cars & Trucks
1990 mazda b2200 2.2 L White Smoke Comeing out of exzaust, smels like antifreeze.
you have coolant getting into your oil. You probably have a head gasket failure. You need to get that repaired a.s.a.p if you keep driving it your going to need a new engine.
Oct 29, 2012 | 1988 Mazda B2200
I smel smoke inside the car.
Possible oil dripping on exhaust. Probably check your PCV valve or valve cover gasket.
Dec 30, 2009 | 1996 Ford Windstar
The unit shuts down after using for 4-5 minutes and I smel burnig
Sadly, light duty machines as yours do overheat and shut off. Shredders are rated for run time. An example: 4 min run time with 60 min off to cool down. I could not find your machine's rating. However, given the 10 page volume I would guess the rating close to the 4 min on.
High volume shredders are rated as continuous run. They should never over heat.
Apr 21, 2009 | Cross Infoguard Shredder SX102M
My gas golf car leak gas over the exhaust is two cycle engine.
It isn't a vw car is a golf cart (for move in the golf fields) thanks any way.
Nov 11, 2008 | 1995 Volkswagen Golf
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
14 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
