Question about HP Compaq Presario S6200CL (B000649LKU) PC Desktop
How do i unlock my computer? the password does not seem to be working, i have it right. i've typed it correctly and even wrote it down.
    Genius:
  • HP Expert
  • 1,325 Answers
Hi
shut down the computer .
simply open the case to expose the motherboard and locate the CMOS battery (size of quarter). Remove the battery and place it back after 30 seconds. close up the computer and start the computer
thsi should remove the need to enter password
thanks foir using FIXYA
Posted on Mar 22, 2011
Why wont quotev load?
your computer may already have a title of that name that didn't load properly, this time right click and save file on desktop, then load from there
Feb 11, 2013 | Computers & Internet
How do i find a key for my linksys router?
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You should be able to see your present wireless network security key on this screen. You can also use this screen to change the key if you want.
If you want to make some changes first select the security mode you want to use.
I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless devices. After the first time they connect to the secured network they should automatically remember the security code. I hope this advice helps you out.
Nov 26, 2011 | Linksys Computers & Internet
How do i find my network key for my router lynksys wirelass wrt54gs
Nov 03, 2011 | Linksys Wireless-G WRT54GS Router...
My phone wont unlock even dough i am putting the right password
I think your right password is not the right one for your phone. Try remember your password again, and if still not the correct one you can try to type wrong password 10 times to unlock blackberry curve 8300, your phone will be unlocked. But you will lose all your data after your blackberry unlocked and you can setup new password again and don't forget that password again :D
May 31, 2011 | AT&T Blackberry Curve 8300 Smartphone
Need to secure my router
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You can set up encryption on your wireless network using this screen. First select the security mode you want to use. I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless computers. After the first time the computer connects to the secured network it should automatically remember the security code. I hope this advice helps you out.
Apr 19, 2011 | Linksys Wireless-G WRT54G Router
I am not able to login my yahoo mail even providing with correct username and password.. It was working well few minutes back. please help asap
If you are absolutlely sure you have entered the right user name and password then maybe the site is down. I just checked my Yahoo mail and it seems to be working. Make sure your CAPS is not on and try again in one hour. If still unable to get into your mail then try getting in from a different computer.
Aug 03, 2010 | Yahoo Mail
How do unlock my messenger?
So many log in tries of an Yahoo ID with wrong password causes lock.. This is a security lock for your Yahoo! ID. If you know the correct password you can unlock it by opening http://www.yahoo.com/r/m6 or http://mail.yahoo.com, for the first time type your ID correctly and type any password(if password is wrong no problem), click Sign In . in reply the same page will appear again... this time type your ID and password correctly, type the captcha verification code correctly as shown in image box and click Sign In. if your password is right your ID will be unlocked.
Thanks for being with us.
All the best.
Nov 30, 2009 | Yahoo Messenger
Locked out
Please unlock your ID by following below steps.
All the best.
Why my yahoo account has been locked?
Too many login tries with wrong password on one ID causes lock the ID. This is a security lock for your Yahoo! ID. If you know the correct password you can unlock it by opening http://www.yahoo.com/r/m6 or http://mail.yahoo.com, for the first time type your ID correctly and type any password(if password is wrong no problem), click Sign In . in reply the same page will appear again... this time type your ID and password correctly, type the captcha verification code correctly as shown in image box and click Sign In. if your password is right your ID will be unlocked.
Thanks for joining Fixya.
Good Luck
Nov 18, 2009 | Yahoo Messenger
When I start my computer and it comes to users account I try to put in my password but it says not the right password I wrote it down but it seems not to be working is there a way around this so I can make...
Hello.
When you created that password, you should have had a security question answered that would help you remember what the password is exactly. Even though you wrote it, remember that it is case sensitive. So if your password was
SystemShock2 it won't respond to systemshock2 or SYSTEMSHOCK2, or anything that isn't exactly as it was written.
If you cannot get in, reboot and keep pressing F8 until you get the safe mode options. Log on as Administrator and change the user account password, or remove it entirely.
Nov 07, 2009 | Microsoft Windows XP Home Edition
HP Compaq Presario S6200CL (B000649LKU) PC Desktop Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
