Question about Sub-Zero Refrigerators
Subzero refrigerator (20 years old!) compressor is noisy and the frame of the refrigerator is very hot.
Was able to get an Authorized Subzero company here this morning with NO emergency service charge. Turns out the fan needs to be replaced and it also needed freon.
Posted on Aug 03, 2008
I need a new compressor for my 12 year old subzero refrigerator.I was quoted $1150 installed.Does this sound high? Marty
Subzero wants customers to call the on these, Call them and most likely they will concession the parts needed to save you some money. I see this a lot as I am a certified repair person. This you save you about 500 or so, but your question is yes, this is about right as the EPA mandates us to recover and collect the charge of freon. The disposal fee and equipment is what makes the rate higher on any refrigerator not just yours.
Original warranty was 12 years parts, I am sure they will help if your using a certified servicer.
Good Luck
Jan 30, 2013 | Sub-Zero 661/F Side by Side Refrigerator
How difficult is it to replace a subzero 650 compressor?
With E.P.A. laws, of you do not have the equipment, I would donate the unit for a great tax break. Any unit that is over 10 years old, always replace to a higher energy effiecient unit. It will pay for it self in a few years, just off the money you saved. If the unit is only a few years old, the new compressor will run $120-$175, plus a coupple hundred for labor.
Jun 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
We have been getting service code 50 for our SubZero -- it;s a 690 model fridge/freezer. I cleaned everything however over last three weeks the error repeats. I reset the board by pulling power from the...
Error code 50 means excessive refrierator section compressor run. Possible causes include: dirty condenser, stopped condenser motor, faulty termistor or an evaporator refrigerant leak. If it is a refrigerant leak it usually shows up as frost or water driplets half way down on the back wall. Clear codes by holding the alarm button in for 15 seconds.
Aug 26, 2009 | Sub-Zero 632 / S
Fridge sounded like a car revving
Check the compressor fixation are okay.Normally it should be on rubber parts fixed to the bottom.If one of them is not fixed it can vibrate.
Jun 30, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
Sub zero bottom freezer access
that unit must be 20 plus years old. There wouldn't be any diferent shelves available for it.
Jan 31, 2009 | Sub-Zero 650 / O Bottom Freezer...
Freezer Compressor Leaks Oil and Stopped Working
Hi I'm a subzero asc (Autorized service center) Subzero would not be responsible, your unit is out of there warranty. Now if the service company your dealing with is any good they can get a new compressor under a part warranty from there part distributor. Also in my many years working on subzero I have never seen oil dripping from the compressor unless you have a leak somewhere in the sealed system. Unfortunately the only thing you can do is see if your service provider will fix the unit. they will charge you labor if they get the part in warranty. It's possible that the service provider did not to the job properly but that's your word against there's. Good luck I hope everything works out for you..
dmparenti
Jan 09, 2009 | Sub-Zero 661/F Side by Side Refrigerator
My subzero fridge no longer seems to be cooling, its only 4 years old. Ive checked all the obvious stuff, do u have any suggestions?
Is unit running? Need to know if condenser fan (by compressor), ref fan, and compressor (the one on the right if this is a ref/frzr unit) are running.
Nov 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Subzero Model 550, freezer not working properly
Blow out the condenser with an air compressor. Make sure the evaporator coil is not frosted up, if so, the drawer may naot have been closed properly, or you may have a defrost problem, (timer, terminator, etc). Possible freon leak in the high side drain loop. Compressor may not be pumping efficiently, could have a bad condenser fan motor.
May 28, 2008 | Sub-Zero 650 / O Bottom Freezer...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
260 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
