Question about Pantech P2020 Ease Crystal Screen Protector ( 3 Pack )
How do I change the front housing on my pantech ease p2020?
  • 4 more comments
  • Kevin Ward Mar 23, 2011
    This phone has the sliding key board. Does that make a difference? I have he screws out and it still doesn't come off.
    Here are pics of my phone housing. As you can see, it has a slide out key board. On the top pic you can see I have three screws removed but cannot get to the three on the other side due to not being to get to the side next to the keyboard. It is like you need to remove the keyboard to get to the screws. I have rempved the screws you previously suggested and cannot get the cover off. So far I have removed 7 screws from the back of the housing and three from one side of the slide out housing.????????
  • Kevin Ward Mar 25, 2011
    I have not received a sufficient solution yet. I have all the screws out as suggested from the other experts, but this phone has the slide out keyboard and there are screws on the underside of the screen when you slide it out. I got to the three on the outer edge but there are some that you cannot see because of the keyboard when slid out. It's as if the keyboard needs removed to get the the screws. With the screws that were suggested to remove the front housing will still not come off. The bottom housing does but not the screen side. If it would help, I can email pics.
    Your info is useful but this phone has the slide out keyboard and there are screws on the underside of the slide out part. I can only get to three of the screws. It's as if the slide out part needs removed to get to the other three. I can send pics if this would be helpful.
  • Kevin Ward Apr 01, 2011
    I still do not have a solution to the problem of changing the screen on my Pantech Ease. All screws are removed except for the ones I can't get to on the back of where the screen slides out from the keyboard. How do I remove the keyboard to get to it?
  • Anonymous Mar 12, 2014
    My wife's hit something on Pantech Ease cell phone and languge changed to French. How do I get it back to English
    Brigadier General:
  • 3,917 Answers
Hi
Please find the instructions here.
Thanks for contacting fixya.com
Posted on Apr 06, 2011
  • 2,069 Answers
To remove the front housing, you should first remove the screws on the back cover. they go through to the front housing. please refer to this picture for the back cover screws positions. hope that helps.
Posted on Mar 22, 2011
    President:
  • 2,047 Answers
Changing mobile phone housing are usually quite straight forward. First take off the back of the phone where the battery goes in next try to determine if the back casing of the phone is screwed to the front. If yes locate the screws and take them out to allow for ease of removal of both the front and the back. Although often times the casing is usually still held in place by clipings which are in built with the casing.
Also you must know that the screws which are used for mobile phones are mostly different from the conventional star of flat screw drivers. So incase your screw driver does not open it do not force it as the screw combination might be different.
Hope this solution has been helpful?
Posted on Mar 23, 2011
  • 6,993 Answers
first, turn of the phone, remove the back cover in order go gain access to the battery. Remove the battery and Sin card (if any).
Get a phone screw driver or any screw driver that can fit into the screws of the phone. Unscrew every visible screws you see on the phone.
After removing all the screws, use a flat small screw driver to pry the phone house/case from the side. Note that you might need to apply some force to be able to successfully remove the front housing/case. But don't apply too much force, let everything you do be with care.
Remove the components on the old phone, put them on the new phone and couple the phone housing/case back together.
Good luck.
2 Suggested Answers
SOURCE: how to unlock the back of pantech ease P2020
Did you mean the battery cover? If so put thumb on arrow and push down to bottom of phone it should slid down and open.
Posted on Nov 30, 2012
My pantech p2020 is not starting
perform power flee
keep holding power button for 15-20 secs ...release and turn on
Apr 21, 2014 | Pantech Ease P2020 AT&T
Changing language back to English on Pantech Ease phone
Follow these steps carefully
1) Open menu
2) Navigate to Settings (the one with gear icon)
3) Navigate to Phone (the one with phone icon, fourth one)
4) Navigate to Language (first one)
5) Navigate to Screen Text (first one)
6) Select the first option.
Hope, you will solve the case.
Mar 12, 2014 | Pantech Ease P2020 AT&T
I bought the p2020 ease used.how to turn on and use?
you can change a new , don't repair it , so much money, you can use this money and buy a new one from www.hopewholesale.com
Nov 27, 2013 | Pantech Ease P2020 AT&T
UNLOCK MY PANTECH CELL PHONE
You can unlock your Pantech cell phone using unlock code.But you need to mention the model ,Country and current network provider to get the unlock code. Visit Onlinegsmunlock.com and select your phone model and give the Country and current network name and get the unlock code.
Mar 28, 2013 | Pantech Cell Phones
How to unlock the back of pantech ease P2020
Nov 15, 2012 | Pantech Ease P2020 AT&T
The phone is locked
Pantech Ease and PANTECH P2020 Is different Phones.They not same Phones,So you need to Unlock it means You can get the Code from here
Onlinegsmunlock and Unlock Your Pantech P2020 and Ease.
Jul 25, 2011 | Pantech Ease P2020 AT&T
Unlock pantech c3 rogers
can you help me unlock my pantech c3 cell phone. I dont have the master code.Pls. Thank you
May 28, 2008 | Pantech C3 Cellular Phone
Pantech P2020 Ease Crystal Screen Protector ( 3 Pack ) Logo
655 people viewed this question
Top Pantech Cell Phones Experts
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
