Question about HP LT4200 42 in. LCD Television
Everything on the remote control works except for the on/off function. What gives?
  • HP Master
  • 8,457 Answers
The remote inter rubber isulater between the rubber an the pc remote circuit board might be worn out.Or the remote CPU chip is dying,the chip control everythings on the remote control.Try website Remotes.com to buy an original remote for a replacement.
Posted on Mar 22, 2011
  • stevesamuel Mar 22, 2011
    This is the first time I've used this site and I think I replied, but I'm not sure it worked. Basically, what I tried to say was that I don't think you're correct because the remote is working - it's only the on/off that's not. And the same is true for the cable remote. It works fine, except for the on off function. So I think it's something in the tv. Thanks.
Bought a genuine remote off eBay for a Harman Kardon HK 3250. Drives everything fine except the volume control. Would it be faulty or doesn't it work due to a wind volume control?
Turning, or winding, volume controls can still be adjusted with the original remote control. You should check to see if it is the exact remote that originally came with your model. Different model remotes might control some functions, but not others. The remote is most likely not broken, just the wrong one.
Apr 28, 2017 | The Audio Players & Recorders
I bought a Zenith universal remote for my Emerson LC320EM2. The reason I bought this remote was to change the aspect ratio. I did a code search for this TV (3715) This code works for almost every button,...
All universal remote control won't work with all the functions to the TV. If you wish to get it properly, you have to buy its original remote control. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Remote Control Codes
Feb 27, 2015 | Zenith Televison & Video
Cannot use any buttons except power and numerical keys. Please help
Setup the remote control with an other code for your TV. Refer its code list. Choose one code, which will give you maximum functionality. nothing more than this to do.
Aug 31, 2012 | Innovage Jumbo Universal Remote Control
MY REMOTE CONTROL DOES NOT WORK AFTER DARK
bdale
You may have IR interference at night because of other items you turn on at night. Try leaving everything off except your TV and receive, try your remote to make sure it functions. Then turn 1 item on at a time, try the remote to see if it works or stops working. Once it stops working, the last item you turned on is causing the interference. It is then a matter of relocating that item so it won't continue to interfere with the remote functions. I hope this helps.
Ray Calo
DISH Network
Nov 22, 2010 | DISH Network IR Remote Control
I am trying to find a remote code for the Cox 7820 remote, that will fully operate my Hannspree tv. The codes provided by Cox will operate most of the TV functions, on the correct buttons, all except for...
I have a Hannspree 42" LCD and I have the exact same problem, the code worked to control all functions except "Power On". I checked the Hannspree web site's support section, it says that their TVs will not work with a universal remote unless you have DirecTV. So why does everything work except to turn it on if they claim their TVs do not work with other remotes?
Oct 25, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
I have a Yamaha RX-V667 Receiver and I need a code for the Remote Control to operate my Topfield PVR model 7160 (Australian release). Yamaha have not published any codes for any Topfield products. Do you...
just bought a Topfield trf-2460 PVR and I have got everything working except the remote control (that came with pvr) sound funtion. I can record and playback with the audio working fine but even after setting the TF remote control to work on the TV funtion, it just doesn't like it, except for the mute button, that and the off function. Any suggestions would be appreciated. Joe
Oct 24, 2010 | Televison & Video
Sleep Function???
In most cases you can set the sleep timer by accessing the menu. Or if it is a learning remote find a button you dont use and teach it the sleep button from your OEM remote.
Apr 15, 2008 | RCA RCR460 Remote Control
RCR460 with Emerson Tv doesnt change channel to input sources
found the answer but it doesnt help.......i got the number to who makes RCA remote controls and called them and talked to tech support to see what i could do for this problem. According to them, some universal remotes are compatible with most tvs but sometimes the remote can only give you the basic functions (chan up/down, volume up/down, #'s, mute an so on.) i dont really understand why it wouldnt work for the input channel but i do know i have a lower end and low priced tv. so....just like everything else the more you pay...the better it is. I checked the remote on my other tv in the living room and everything works just fine, even the input button. Hope this helps...
Mar 13, 2008 | RCA RCR460 Remote Control
Symphonic wf2720
I haven't found a way without a remote except to unplug everything except a vcr or dvd, no other channel inputs and run the channel set up function. It will only recognise the one it can read and it will only leave you with the game channel... give it a try.
Dec 26, 2007 | Symphonic WF104
HP LT4200 42 in. LCD Television Logo
67 people viewed this question
Top HP Televison & Video Experts
Computer Links
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
