I-cannot-fix-the-spacebar.it-doesn't-provide-a-space.please-help
    Problem Solver:
  • 28 Answers
Try to clean your keyboard key. check the buttom of the key if there was dirt or something cloging in the key to be press. or the worse case scenario of that is you need to buy a new keyboard..
Posted on Mar 22, 2011
    Genius:
  • 1,325 Answers
Hello
i assume you have a laptop (notebook) ? if so, the space bar as in all keyboards has an activation button when depressed and if something like a plastic potion is broken off or missing, it will skip or mis the activation switch on the circuit board. you will have to replace the keyboard
if youc an give me the model of the computer and all other part numbers loacted on the back of the computer i can determine what you will need (as in the keyboard p/n required )
thanks -- hope this helps
    Master:
  • 434 Answers
Time to replace the keyboard....
Fix spacebar
On a Desktop, just purchase a new kb for $16 or so. On a laptop, it's an involved process to replace the kb.
To get a space without a spacebar, try these two suggestions:
- Press Alt/32 (that's Alt with 3 2) then release the Alt key.
- Run OSK and click the spacebar.
The actual model number MIGHT get you a repair procedure in a Google or Youtube search for "repair spacebar".
Oct 28, 2013 | Computers & Internet
(Remington Streamliner) the space bar automatically tabs instead of moving one space forward. How do I fix this?
This can mean that the spacebar is not being tapped hard enough, the spacebar is sticky, the escapement is sticky, or the spacebar linkage needs adjusted. If the letters do not cause this, then the escapement being sticky is less of a concern. Sometimes the touch on the spacebar is right on the point where the escapement mechanism just barely escapes and doesn't lock in. First try tapping the spacebar more firmly to see if this helps.
Aug 14, 2013 | Office Equipment & Supplies
Spacebar on keyboard makes my computer go to sleep mode
Sounds like your keyboard is sending the wrong signal (the one telling your PC to enter sleep mode) to your motherboard when you press space key, which (if true) would indicate it's faulty. It could also be you've contracted a virus and is playing a particularly nasty practical joke on you (let's hope that's all it does). Try connecting another keyboard to your PC and see if that helps. If it doesn't, then you'll need to clean your computer of any viruses. Try also disconnecting your mouse and see if that changes anything. If your keyboard comes with a shortcut utility software for it, run it and check there's no shortcut set on your keyboard's space bar. You've additionally specified you're not using wireless keyboard, but could you also please write what OS you're on?
Mar 23, 2012 | Compaq Keyboard
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
I have a mac Laptop and the space button on the bottom of the keyboard is stuck down .. can this be fixed?
It is tricky to repair the space bar. It has a plunger in the middle and is held in place by tension clips. The tension clips are what make the spacebar pop back up. Usually one clip comes loose and the other side still bounces. If the spacebar is stuck down with no bounce, I would check to see if there is something wedged under the spacebar. Get a can of compress air and blow under it, hopefully this will release whatever is under there. Only take the spacebar off carefully without jerking it upwards. If it breaks the clip holder at each end, you will need a new KB.
Good Luck.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 31, 2011 | Apple Computers & Internet
My spacebar key is no longer working properly. I have an acer aspire laptop 5735Z . I deliberately pulled the key off to clean underneath and then just clicked it back on, thinking it would work normally....
There is usually a metal piece under the space bar, if it isn't seated properly the space bar will teeter. Try to remove again and see if they metal bracket is seated correctly.
Oct 18, 2017 | Acer NSK8458AN Keyboard
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
Sep 17, 2009 | Acer TravelMate 5530-5207 Notebook
Spacebar/will/not/space
just take it it up the spacebar key with a pen or anything like a pen and clean inside of the keyboard which is the spacebar is placed and fix the spacebar again and type
Apr 23, 2008 | Computers & Internet
My keyboard is inserting spaces where they don't belong.  it is usually around R's, N's and spaces (I  press the   spacebar once it it inserts 2 or three spaces, the  faster I type the   worse it gets.)...
You should open the key board.and clean space key and change rubber cap.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Logitech 967437-0403 Keyboard
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
