Question about Canon Rebel XT / EOS 350D Digital Camera
My eos350d camera has stopped working. There is no sign of life at all. I have tried to change the battery and even the small disk battery, but there is still no sign of life. Is there any chance of the camera working again, or is it completely dead? If there is a chance of the camera working, what can be done?
  • 32 Answers
Annmelba,
I think you'll find the EOS to be a fairly durable series. Just to cover your bases, I would clean the inside battery contacts with a Q-tip and some alcohol. That said, I suspect you may have to take your camera to an authorized repair facility - a quote should run you about $60 if the device is out of warranty and depending on the nature of the problem, the repair could cost considerably less than a new camera.
Thank you.
Posted on Mar 22, 2011
  • Me Butler May 03, 2011
    Did you find a solution to this problem. My Canon JUST did this also! Please advise!!!
  • Jason Caldwell
    Jason Caldwell Dec 12, 2011
    My Canon has done the same thing. It will not even show signs of life when connected to a PC. Cleaning the connections with a microfiber cloth did nothing, nor did cleaning with a q-tip and alcohol.
Error 99 on Canon EOS350D
Cannon does not say what error codes above code 02 mean. They only suggest the costumer to make contact with the nearest Canon service centre.
But connecting a non autofocus lens from an other brand, could be something the camera can't cope with. And the most Canon (and other brand) camera's can't focus when a lens has a aperture greater than f/1: 5,6. The f/1: 6,3 or perhaps even f/1: 8 is one or two stops to much for your camera. Special when you try to use this lens in no bright places.
Nov 12, 2013 | Rokinon 500mm f63 Mirror Lens for Nikon...
My Sony Cyber-shot DSC-S600 stopped working. I press the power button and nothing happens. I tried changing batteries, but it shows no sign of life. It was left in the trunk of my car overnight, inside a...
Remove the batteries and SD card, leave the battery door open, and put the camera in a jar along with a dessicant bag or a small bag of uncooked rice that has been opened. Put the lid on the jar and let it sit for a day or so. This should absorb any condensation inside the camera that may be keeping it from working properly.
Jul 02, 2017 | Sony Cyber-shot DSC-S600 Digital Camera
Wont switch on
Sounds like you've damaged the cut out switch for the memory card door. this can be fixed by bypassing the switch on the board
Oct 10, 2009 | Fuji FinePix S5700 Digital Camera
Same problem..lots of life left but camera says CHANGE
How many volts do the batteries have on each of them? Many devices will not work if even one battery is less than the rated value of the battery like 1.5 volts. One battery low or bad draws down the others in series with it. It will be seen as a resistance and not a power source.
Try a new set or if you can use a fresh set of Alkaline.
Sep 12, 2009 | Canon PowerShot A590 IS Digital Camera
Vtech kidizoom camera
We had the same issue. After turning on, nothing on the view screen and the buttons didn't work. The camera could turn on, the turn on screen and sound happened and we cold turn off (show off screen and sound)...even after changing batteries. It was like that for a week.
I found it had to do with TV connector slot. Thinking back, my daughter had been playing with the TV connector right before it stopped working. I took a small hair pin and put it in the TV connector slot, lightly wiggled it and the camera sprung back to life. I'm guessing the camera hardware was acting like it was still plugged in...hence turning off the view screen.
Anyways, hope that helps someone.
Jul 25, 2008 | Vtech Kidizoom Digital Camera
Camera will not turn on
Honestly, drop it again.. this worked for me in december when i had the same problem.. just tap it on a table a couple of times, reverse the effect. This worked for me!
Jul 19, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Sony cybershot dsc-n1 took 6000 pics and stopped working Screen went white before died with lense extended no sign of power next cybershot DSC-N2 took 15,000 pic and died just refuses to turn on. no power...
no non of sony cameras come with any life pan
ya they are telling something baout life cycle
but i have cybershot with 29000 pic and my friend is having about 20000 so if your cameras is in warrenty period then go to sony service station they will fix it
or if you r out of warranty period then go for repairing your camera probebly changing CCD of your camera will fix this problem
Mar 26, 2008 | Cameras
Camera just stopped working
stick a volt meter on the battery after charging if its really low or zero battery needs fo be replaced
Oct 02, 2006 | Nikon Coolpix 4300 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
409 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
