How do you replace the front outer tub in a front load whirlpool duet- from the rear????
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
The service manual will tell all. Follow the link below to download....
Service Manual
Kelly
Posted on Mar 22, 2011
My whirlpool front end load duet washer has an inner drum which was making increasingly loud noise and now seems loose from the outer drum
I am sorry to say that fixing this is a major repair. it involves replacing the inner tub and at least the rear half of the outer tub. Getting to these parts involves almost total dis-assembly of the washer. It takes me 2.5 to 3 hours to do this job generally, and the parts cost is substantial.
If I were you, my first step would be to contact Whirlpool and try to get them to cover the repair, or at least the parts.
If you would like to attempt the repair, I will gladly give you some pointers and help you through it, just be aware that it is a complex procedure.
Let me know if you need more help,
Mainetech
May 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do you remove the rear tub bearings on a whirlpool duet front loader. tub is out of washer but can't get shaft out
you have to buy the whole tub or basket,each part is around 230 dollars.the basket part number is W10250573 and it's around 215 dollars,this is the part with the shaft on it,the rear outer tub part number is 285984 and it's around 225 dollars.
Apr 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool Duet washer model GHW9150PW0 that began to thump during the spin cycle. I removed the front and it appears the inner tub is off-center or out-of-round. Further, it has worn off the...
There is a lifetime warranty on this main basket. and 10 years on the outer front and rear buckets. My unit is 7 1/2 years old. and had the same problem. One of those 3 spokes connecting the main shaft to the rear bucket cracked and killed the front outer bucket. Whirpool tried to tell me I needed a professional to diagnose it but I told her the rear outer bucket was cracked, leaking water, and shredded the front outer. She sent me all three parts for $0! It took 2 hours to get apart and that was me being super careful. The parts will be here tomorrow morning! I did needd to buy 2 shocks at $21.00 each.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet makes an awful banging noise when a load of laundry is in the spin cycle. It is completely level and I cannot figure it out.
reach inside drum that turns and try to move it up and down. If there is any movement the spider at the rear of the drum is broken. Will need inner drum and outer rear tub with bearing and seal.
Nov 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool front load duet washing machine. The white plastic around the drum is cracking and the machine is leaking from the front underside. Can this be repaired?
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud knocking and vibration during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet washer. It sounds like
the rear tub.
and tub assembly.
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I need a bearing for the ghw9100lw2 is that sold separate from the rear drum
No. the bearing is molded in the rear drum. The rear outer tub runs around $200 and it is not an easy job. I recomend having a technician replace it.
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The inner tub is out of balance and rubbing against the outer tub
The rear bearing is part of the back half of the outer tub. In some cases the basket will need replaced also if the shaft is scored. This is a big job. In most cases whirlpool will warranty the parts for 10 years but not the labor. Will need to check in your owners manual. Hope this helps
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
